Old 08-08-2014, 11:23 PM   #11
DennisAN
DennisAN's Avatar
You can kind of flush the system by jacking up the front end, removing as much fluid out of the reservoir as you can with a syringe/turkey baster, refilling, starting the car and turning the wheel gently, lock to lock a couple of times. Repeat until you have run through about 3/4 of the can of fluid, save the rest for top ups.
I'm used to doing this on other cars, BUT the Boxster has long PS lines going up and back from the front of the car. The factory manual says capacity for the PS system is 1.0 liter (of Pentosin CHF 11 S). But I was only able to suck out and refill 20 cc of fluid from the PS reservoir today. That's only 2% of the system. At this rate a dozen repeats of suck and refill may only change about 20% of the fluid.
Is there any trick to getting more than 20 cc out of the reservoir? I used a large syringe with a clear vinyl tube extension.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
