Old 04-08-2012, 04:39 AM   #1
Carpet foam is wet.
The car has been on stands for more than 30 days and has not seen rain for that period. Removed the driver side carpet behind the seat to install IMSG and noticed the foam is dripping wet. I have no idea what to make of this. Anyone ever have this issue?
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 04-08-2012, 02:53 PM   #2
did you pick up one of Danger's Birds ? accidently?
milliemax is offline   Reply With Quote
Old 04-08-2012, 05:52 PM   #3
Moderator
It could be a blocked drain line. The boxsters have concealed tubes that drain water from rain which become blocked overtime, thus resulting in inadequate draining and getting inside the interior.
Of course- you mentioned there was no rain in that period. So-
Perhaps a coolant leak? May be cracks in the coolant reservoir.
Pulled from this thread:
http://986forum.com/forums/general-discussions/30565-coolant-leaking-wet-carpet.html
Or even a blocked AC condensation drain?
Hope that helps.
Old 04-09-2012, 11:55 AM   #4
I'm afraid danger might come after me if I answer that question. :chicken:
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 04-09-2012, 11:58 AM   #5
Hope that helps.
I think it's blocked drain line. Don't have any coolant issues and it's not colored either. You actually might have solved another problem - water in the Frunk. Thought it was a bad seal somewhere but from the diagram on the link it's probably the condensation. Thanks very much!
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 04-10-2012, 04:02 PM   #6
I know for a fact that he has so many one or two missing would not matter..
