Old 03-28-2012, 03:45 PM   #1
Check engine light
Well, it sure was a good run. Nearly 2 years of trouble free boxstering!
Got a CE light a couple of days ago.
P0153 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Below Lower Limit P0154 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Interruption of Signal
P0341 Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+
P1397 Camshaft Position Sensor 2 - Signal Implausible, Short to Ground, Short to B+
P0102 Mass Air Flow Sensor - Below Lower Limit
Borrowed a durametric cable and I'll clean the MAF and swap the O2 sensor to troubleshoot those codes, but the camshaft sensor codes make no sense. They're on opposite sides of the motor. So where do they lead and how do I access it to check the connection?
Old 03-28-2012, 04:33 PM   #2
Johnny Danger's Avatar
When the time comes to replace the MAF sensor let me know . I found a source for inexpensive sensors .
Old 03-28-2012, 04:36 PM   #3
Topless's Avatar
Randall,
Did you have a low battery recently? These are pretty random and look more like a DME hiccup under low voltage than real codes. I would write them down, clear, and see if they come back. I let the batt in my car get real low once and it spit out random codes like this. I charged the batt, cleared the codes and they didn't come back. If they return look for a rodent nesting near your DME in the rear trunk.
Old 03-28-2012, 07:26 PM   #4
Topless, the car did sit at a body shop for two weeks and may have a low battery.
I shall use the durametric cable and software to clear the codes and see if that does the trick.
Wouldn't that be nice!!!!!
Old 03-29-2012, 05:22 AM   #5
PM sent - brother .
Old 03-31-2012, 04:56 PM   #6
Topless, I think you were right. I cleared the codes and a low voltage one too (that didn't show up on the crappy code reader Pep Boys used) and drove the car around a while today. No CE light. Trickle charger on the battery, btw.
I'll take it out tomorrow as well and see if the CE light returns.
Pity is that if I took it to a dealer, I'd be out hundreds for a new MAF, possibly a set of O2 sensors, and a new overpriced German battery, huh!?
Old 04-01-2012, 06:42 AM   #7
97 Boxster's Avatar
Danger, I'd be interested in your source for an inexpensive sensor if you dont mind sharing it. I know its only a matter of time before I have to replace this and so I am gathering a few parts so I have them on hand. This is one of those parts.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 04-01-2012, 07:07 AM   #8
I'll send you a PM.
Old 04-01-2012, 07:36 AM   #9
I've learned through experience to clear any first-time code I get and wait for it to come back. More often than not they don't come back. On all my cars, not just the Boxster.
Old 04-01-2012, 11:27 AM   #10
Topless's Avatar
+1 for the vast knowledge base at 986forum. Lots of varied experiences here make this site extremely useful when troubleshooting.
Old 06-21-2012, 08:18 AM   #11
billfry's Avatar
I know this is a bit old, but I would appreciate the source information as well.
Just came back from deployment, and my '01 is showing check engine. I forget the exact code at the moment, but it is an O2 sensor (will have to check again for which one).
Thanks.
billfry is offline   Reply With Quote
