02-24-2012, 02:56 PM
#1
Fuel Filter Question - 2001 Boxster
I am about to replace the fuel filter on my 2001 Boxster and understand that I need to pull the fuel pump relay and crank the engine a few times to lower the pressure. I have the 101 projects book.
Where is the fuel pump relay and how do I "pull" it? Anything else I should know?
Thank you
2001 Boxster Guards Red
02-24-2012, 03:42 PM
#2
Above the fuse panel under the driver's side dash there is a second panel with relays; the fuel pump relay is on the top row, second from the left.
02-24-2012, 09:35 PM
#3
Or just pull the fuel pump fuse, much easier than the relay.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
02-27-2012, 03:02 PM
#4
Thank you all, I will try it this weekend.
04-16-2017, 04:12 PM
#5
That would be fuse C4?
'99 black 986
04-16-2017, 06:21 PM
#6
Thank you
I just recently replaced my fuel filter and didn't do any of these steps. A cup of gas drained out but otherwise very easy to manage. I did remove the fuel cap.
04-17-2017, 09:37 AM
#7
Ditto to Syracuse
04-17-2017, 11:28 AM
#8
07 Carrera S Cab
Ditto Ditto. Did not do anything other than replace the filter.
04-17-2017, 11:54 AM
#9
fuel filter location?
Could someone please confirm the location of the fuel filter on the 987's (2007)..?
for some reason I have not seen mine and at 97k should be planning to replace it.
Thank you!
04-17-2017, 12:01 PM
#10
Luckyed
For those of you who have successfully changed out the fuel filters on your 986's, what were the reason(s) leading up to your decision?
I am thinking of going the same route on my 2001 2.7 in an effort to eliminate an intermittent hesitation around 4500 RPM.
Thanks.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
04-17-2017, 12:52 PM
#11
Administrator
Thank you!
I believe for the 987 they integrated the filter with the fuel pump/sender unit. Starting in 2002, Porsche moved the filter to inside the gas tank, and called it a "lifetime" filter that never needs to be changed. This and more info can be found at our DIY article I linked below.
The fuel filter is integral in the tank unit and no longer requires changing. A reduction in deliver rate can be detected via the mixture adaption.
Anyone needing a step by step on the replacement for the 986 and wanting more info can check out our article here: Porsche Boxster Fuel Filter Replacement | 986 / 987 (1997-08) | Pelican Parts Technical Article
04-17-2017, 01:38 PM
#12
07 Carrera S Cab
Thanks.
I didn't have any symptoms at all. I changed it cause Porsche recommends that they be replaced every 60k miles. I had hit 60k, so changed it.
04-18-2017, 06:46 AM
#13
Thank you Luccia!
04-18-2017, 10:50 AM
#14
Luckyed
Thank you for the reply.
09-22-2019, 04:13 PM
#15
This is not as easy as they say. I could not release the clip on the filter next to the ground wire; not room, the ground wire was tight (probably crimped with pliers). I gave up put everything back. I have 41.5 K miles i'll wait till I hit 60K and take to the dealer.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
09-23-2019, 03:17 AM
#16
That's funny, I don't remember having this problem. What year is yours? Maybe there's some year-to-year variability.
I don't recall having much of a problem changing it out, but—at 104K now—it's been a good while since I hit 60K, so the details are a bit fuzzy in my mind.
09-23-2019, 03:48 PM
#17
I have a 2001 S. I expected it to be <1 hr. 2 hrs later, I still could not get the dang thing off.
09-23-2019, 04:03 PM
#18
I haven't changed the filter on a Boxster, but I know some electrical connectors have a locking tab. You may need to press the little tab to release it.
I'm not sure this is your situation, but here's a pic of a connector with a locking tab. The tab is at the tip of the pen. You can't pull the connector off without pushing on that tab.
09-23-2019, 05:24 PM
#19
Wow, that's weird. Mine's an '01 S as well.
I definitely didn't have to fool around with any tiny locking tab, as described by piper. As I recall, I was working at arm's length, without an over-abundance of light. And my eyes (even a few years ago) weren't as good as they once were. For whatever reason, somehow it seems like you have a different situation...
09-24-2019, 03:59 AM
#20
I wasn't saying that they absolutely have the locking tab. I've never changed the filter, but I have had experience with difficult to remove electrical connectors, and they all had locking tabs. Since Ciao had problems with it I was proposing that it may have a locking tab.
