Old 02-16-2012, 02:03 PM   #1
200 Boxster S Top
Hey, I recently bought a 2000 Boxster S with about 30,000 miles on it. I have had it for a month, and it all seems pretty good (it was inspected by a mechanic), but now I cannot get the top to open. Specifically, the release won't work and the dash light indicates that the top is open, even though it isn't.
Is there a quick fix for this, or do I need to take it to my new local neighborhood mechanic.
Any thoughts would be greatly appreciated.
bryan__t is offline   Reply With Quote
Old 02-16-2012, 02:15 PM   #2
Ex Esso kid
Check the micro switch in the handbrake, the dash light might be lit because the open or shut cycle didn't complete. When you say the release wont work I'm assuming you don't mean the aluminum handle that you unclip to begin the operation.
Old 02-16-2012, 02:33 PM   #3
THanks Ghostrider. I actually do mean the aluminum handle that I unclip to begin the operation. It doesn't budge and I am afraid that I will break it if I apply too much pressure.
Old 02-16-2012, 02:40 PM   #4
boxster6354's Avatar
Have you tried holding down on the button to close until the light goes out, then try to unleash ?
Old 02-16-2012, 02:44 PM   #5
I will try that one next. Thanks!
Old 02-16-2012, 06:14 PM   #6
WV Boxster
wvboxst3r's Avatar
just to make sure, you push up on the middle section to release handle then pull the handle down. The handle wont budge until middle section is pushed.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
