Old 02-14-2012, 08:09 PM   #1
seningen's Avatar
Coolant Q, low then mid-level
Noticed the other day that my coolant was a bit low.
When I got home and checked again -- it was mid-level right about
where the MAX words (not line) is.
This evening before heading home from work -- I checked again and
it was low, just below the low mark.
Let it warm up -- maybe 5 min, but it never rose.
So I ran out of patience, jumped in and drove home.
Once again it was at the mid-level point.
I opened the pressure relief valve, I could hear a little gurgling, but nothing serious.
I opened the coolant cap (carefully and with a rag), I could see wisps of steam,
but not a lot. this was while car was running.
No signs of coolant in oil or vis-versa. No CEL, misfires, coolant light.
Everything is running fine -- temps were fine.
Nothing out of the ordinary.
I have no evidence of leaks anywhere -- but I haven't pulled any of the engine trays and looked around.
thoughts?
mike@lonestarrpm.com
Old 02-15-2012, 03:56 AM   #2
The coolant level goes up and down slightly, up when its hot and down when its cold. Just keep an eye on it when its cold and if the level drops significantly over time. then start looking for a leak.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 02-15-2012, 04:38 AM   #3
WV Boxster
wvboxst3r's Avatar
have read check trunk under carpet. the tank in trunk develops leaks and needs replaced.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 02-15-2012, 11:37 AM   #4
thoughts?
Mike-
Pull a vacuum on the cooling system while the car is cold, see if the level changes due to air coming out.
