Old 02-06-2012, 06:35 PM   #1
Rotor screws are toast
The screws holding the rotor to the hub are soft and are hard to get out. Tried heat, penetrating oil, wd40 and no luck. If I drill the head out am I looking at some major issues? Can I take it to a machine shop and have them thread it for me again? Doable?
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 02-06-2012, 07:11 PM   #2
Theoretical propagandist
Eric G's Avatar
Have you tried an impact screw driver? They are made for taking out troubled children like this? If you a Sears, Home Depot or Lowes I have seen them at all of these locations.
They are not that long and mine required the use of this to get two of the four rotors off.
Best of luck!
Old 02-06-2012, 07:16 PM   #3
I used a lot of heat from a propane torch to get mine out. An impact wrench is a great suggestion. After that, drill a hole down the middle of the screw and use a wrench and an "easy-out" which shouldn't harm the threads (if you're careful).
Old 02-06-2012, 07:28 PM   #4
jacabean's Avatar
there are some good videos on this up on youtube. drilling it out is not that hard.
Old 02-06-2012, 07:56 PM   #5
I agree on the impact driver. You'll need it eventually, and it does the job instantly and reliably. I had to use buy one when doing my first rotor change a decade ago (!), and have needed it once or twice since then. I think it's whenever someone ELSE does the work and puts the damn screws on too tight.
trygve is offline   Reply With Quote
Old 02-07-2012, 02:47 AM   #6
Impact driver is how I've gotten mine out. And I use anti-seize when I put it back together.
I have had to drill out the screws (on an Acura). It's a PIA, but possible.
Good luck
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 02-07-2012, 03:09 AM   #7
Thanks guys. I'll add an impact driver to the arsenal. I want to avoid drilling. Somehow it doesn't work for me. Too many ones still stuck in the car!
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 02-07-2012, 08:02 AM   #8
jcb986's Avatar
I had to drill just one of mine, then I used an EasyOut on the end of a Impact tool. Drilling was not that bad...just enough to get the EasyOut to bite.
Old Hippie Young Heart
Old 02-07-2012, 06:14 PM   #9
I just replaced the fronts this past weekend...didn't even bother with anything else, I used an impact screw driver and they came right off.
rigofloresjr is offline   Reply With Quote
