Old 02-04-2012, 01:07 PM   #1
clock keeps resetting when turning on the headlights
I have been experiencing a strange phenomenon.
If the ignition is on, and I go to turn on the headlights, the entire dash would switch off (indicator needles fall, clock resets, current mileage resets) for a brief second, and switch itself back on.
This only happens if the ignition is already on. It can't be re-produced if:
1. this has already happened once during this particular "ignition on" period - i.e switching the headlight off and on won't reset things again if it's already happened once during this one ignition on period
2. turning the headlight to on first, and then starting the car, avoids this problem
The battery is a good brand and only 6 months old. and the ignition switch was replaced last year.
Any thoughts?
--1989 Mazda MX6 GT
--1997 Porsche Boxster
--2005 Lexus RX330
--2007 Maserati Quattroporte Sport GT
Jinster is offline   Reply With Quote
Old 02-04-2012, 03:23 PM   #2
Jager's Avatar
When you say the ignition is on, is the engine is running?
Jäger
300K Mile Club
Old 02-04-2012, 03:49 PM   #3
landrovered's Avatar
Check to make sure the leads on the battery are tight, mine was doing the same sort of thing and the negative lead was a tad loose. Tightened it up and no more clock mysteries.
2001 Boxster S 3.6L, Zeintop
Old 02-04-2012, 06:58 PM   #4
Something to consider is that a failing ignition switch (electrical portion) can result in strange electrical problems. Lots of posts. Search on "ignition switch". Here is a link to a related thread: http://986forum.com/forums/general-discussions/28880-ignition-switch-problems.html
