Old 01-23-2012, 06:51 PM   #1
Unhappy Trouble re-fitting CDR-220 radio
Help re-fitting the CDR-220 radio unit.
I've successfully extracted the unit, attached an iPhone cable and routed the cable around the back of the unit. However, when I try to re-seat the unit back into the console it gets 'stuck' about 3/4 of the way in. Obviously it is catching on something, but as the radio is 3/4 in, there is no way see what the problem is!
Any suggestions please? Is this a common problem with a common cause?
Wicky is offline   Reply With Quote
Old 01-24-2012, 02:43 AM   #2
07 Carrera S Cab
Boxtaboy's Avatar
Have you removed the keys first? If not, press the blue tabs in on each side of the radio to remove the keys. Then, push in the radio.
Old 01-24-2012, 03:29 AM   #3
WV Boxster
wvboxst3r's Avatar
It is very hard to put back in. I had to jiggle, lift up and push down on front to hit the bracket just right. I seemed to be at the wrong angle, once I hit the correct angle and the back started in the bracket it went just a tight fit. Start the up and down where your stuck at.
Goodluck and go easy it is just barely off.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 01-24-2012, 03:57 AM   #4
Ex Esso kid
A little clean grease applied lightly will go a long way, just don't go nuts with it so it doesn't extrude out the sides of the unit, try putting it in with the faceplate off too.
Old 01-24-2012, 05:54 AM   #5
Andrew McD's Avatar
I was told to remove the aircon unit above (there is a bit of trim that goes around the edge of the aircon, remove it and then there are two screws ) once you have it out you can direct the unit back into place. Apparently there is a danger of slicing cables, and actually its much easier to direct it in.
Twitter if anyone is interested... @JAZ5788_Boxster
Boxster 2.7 with a few mods: RSS Under drive pulley, Dansk OEM look polished stainless steel sports silencer, K&N air filter, Full new M030 Sports Suspension, 997 Gear selector, and a load of other OEM styling upgrades.
Andrew McD is offline   Reply With Quote
Old 01-24-2012, 08:02 AM   #6
There are two clips in the rear at about 3/4 of te way in. Put the radio back top pon the bottom of the top side of the clip, push down the radio slightly and make sure the back of the radio lifts the clips a little, while doing that push it in.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 01-24-2012, 08:51 PM   #7
Thanks all. It seems returning 24 hours later and a lot and then some more "jiggling" around did the trick!
Tags
fitting , installing , iphone , radio , trouble
