Old 01-23-2012, 07:32 PM   #1
Norcal986
California Exhaust Question
Looking for advice for exhaust info for 2001 Boxster S ( 4 Cats).
I want my car to be legal and i bought headers for it which have two O2 sensor ports each, but I need to know if I can replace the to stock cat’s with just two and still have it pass California Smog tests…? Also, did I mention that I don’t want to spend a ton either for it…
tikal1 is offline   Reply With Quote
Old 01-23-2012, 09:25 PM   #2
Your car is unlikely to pass smog. You're probably going to get a MIL (check engine) light because of the headers (you can't pass smog with a check engine light). If you wind up at a shop that knows anything about your car, you will also fail the visual inspection. I have no idea if you'll pass the tailpipe sniffer.
Unless the headers you bought are CARB certified (and I can't imagine they are), your car will not be smog legal. Tampering with the emissions system, especially in the People's Democratic Republic of California, is a no-no.
If you haven't already installed your headers, save yourself the hassle and sell them to someone else...
sd_boxster is offline   Reply With Quote
Old 01-23-2012, 09:28 PM   #3
Topless's Avatar
Technically aftermarket headers are not street legal in Commiefornia but if nobody looks at them, they don't throw a CEL, and you pass the sniff test you may pass smog inspection. Your primary O2 sensors need to be pre-cat, and your secondary sensors need to be post-cat. With a good set of cats your car should run clean with no CEL. I would probably save the headers for a dedicated track car and sleep better knowing that the KGB wouldn't show up in the middle of the night and impound my daily driver.
Old 01-23-2012, 09:38 PM   #4
Well put, Topless. However, OP stated "I want my car to be legal." Even if he/she passes the emissions test, the car won't be legal if non-CARB-approved equipment is installed.
Old 01-24-2012, 11:24 AM   #5
With two O2 sensor ports on each side, this header might be able to pass the smog test fairly easily because the computer will be able to adjust the air/fuel mix to minimize emissions.You'll need all four O2 sensors (pre and post cat) for the ECU to tune the air/fuel mix properly to pass the emissions test. If you get rid of the post-cat O2 sensors, the engine will run fine but the emissions might fail the test.
If you do this, be sure to drive the around for 20-40 miles in varying conditions to get the ECU to fully adjust for the header change.
Its unlikely that the test tech is going to get under the car to do an actual visual inspection of the headers and even less likely that he'd know what he's looking at.
With all of that being said, you'll have to check with the header manufacturer to find out if their product is CA approved. If not, then its technically illegal but you still might be able to pass the smog test.
Old 01-24-2012, 01:39 PM   #6
Registered Boxster abuser
healthservices's Avatar
There are a number of things you can do to make the car pass the sniffer and not have any codes....
However if anyone does a visual and knows what the car came with before, it is a automatic fail.
As a past tester I am required to see and check that all 4 O2 sensors are there, as well as all 4 cats and if the cats were replaced in the past it must also have the proper tags to say they are legal in the state.
Old 01-24-2012, 09:26 PM   #7
ChrisZang's Avatar
Just to be clear:
Do you want your car to be legal or do you want it to pass smog?
Because hoping that your car is legal after installing illegal exhaust hardware is an oxymoron....
Old 06-05-2015, 03:16 PM   #8
Dlirium's Avatar
Reviving this Thread rather than starting a new one - couple of things -
1) I'm in CA and have not even CONSIDERED changing the headers due to CA smog laws. I HAVE changed the exhaust and, in fact, since there isn't a O2 sensor on the secondary cats, I put a test pipe in and it runs great.
2) Since CA doesn't sniff anymore on certain model years (including my 2000 S), that 2nd cat's weren't an issue. And I have a guy that is WAY to lazy to get under my car to check, so I'm good with visual
3) This got me to thinking about headers. And since my boxster is mainly a track car, I'm thinking of putting them on (research tells me they DO make a difference on our cars).
Question is - for those that have headers, and especially those that have headers in CA -
1) What all is involved in KEEPING the primary cats and O2 sensors with headers? Is it a big project, or pretty much plug and play?
2) Do you feel the performance improvement and potential new life of crime is worth it?
Thanks for your input!!
Old 06-05-2015, 03:36 PM   #9
I don't have an answer to your question but can you elaborate more on item 2?
My 02 is due for registration and it states it needs a smog certificate.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 06-05-2015, 03:50 PM   #10
EJ-Fresno's Avatar
They do not use the tail pipe sniffer anymore but plug their computer on the OBDII port and run the tests through a software.
They don't even kneel anymore at the back of the car so less and less chances that they find out if you installed cat pipes / headers.
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 06-05-2015, 04:18 PM   #11
Dlirium's Avatar
Yeah, exactly what I was thinking!
Old 06-05-2015, 04:37 PM   #12
We do smogs and yes we open the engine cover as well as look under the car. Visual is legally still part of the inspection.
Old 06-05-2015, 06:19 PM   #13
Thanks. It's been two years since I last smogged any of my cars and I have 4. That cycle is this year and I already have two to smog. I'm not sure of this method is easier to pass or not.
2008 Boxster S PDE2
Old 06-05-2015, 08:36 PM   #14
Yes the cheap tester will not erase the history, the Durametric will. You have to look at your emissions label there is what's called the 49 state emissions and there's a California 50 state legal emissions. State law requires you to have whatever the car came with.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Old 06-06-2015, 07:03 AM   #15
This is from the torque app on my phone with the $15 bluetooth connector.
Just drive until the readiness test are complete...
Old 06-06-2015, 07:28 AM   #16
Great info for those of us that needs to smog.
Illnsee if my Dashcommand has this. If not Torque app it is.
Thanks.
2008 Boxster S PDE2
