Old 01-17-2012, 11:55 AM   #1
Key Transponder not Working
My key transponder hss stopped working. I've put in a new battery so its not that.
Car is a 2003 Boxster w/ 96.000 mi.
Any ideas?
kaki3152 is offline   Reply With Quote
Old 01-17-2012, 12:09 PM   #2
Ex Esso kid
Try using it manually in the door, I read somewhere that it can reset this way but I never had to try it. Otherwise, I would think only a dealer reprogramming will do.
Old 01-17-2012, 06:54 PM   #3
Matt
MileHighBoxster's Avatar
Welcome. There are several things that can be wrong. Search for key fob as there are many, many threads about this. Can be guts worn out, programming, or power failure (even with a new battery). Have your dealership test it and reprogram if it's working per specs.
Matt
2004 Boxster S, Guard's Red, 6 Speed
MileHighBoxster is offline   Reply With Quote
Old 01-18-2012, 05:38 AM   #4
The trick that worked for me was to open it up, put the battery in with reverse polarity for 30 seconds or so, then flip it back. Worked like a charm. Strange but true.
2002 Boxster S Meridian\Boxster Red 6-spd
2006 Audi A3 2.0T Arctic White\Beige DSG
2010 BMW 535xiT Alpine White\Natural Brown
jakekit is offline   Reply With Quote
Old 05-21-2012, 09:31 AM   #5
97 Boxster's Avatar
Ordered a new KEY FOB off of Ebay and replaced my broken key head and its working great. Paid $39 for the 2 button key head (no electronics).
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 12-13-2012, 01:21 PM   #6
srad34's Avatar
Wow, had an intermittent fob issue, new switches, battery etc, seemed fine then just stopped working!
Tried Jakekit's battery reversal and it worked!
While this is fantastic news, how does this work, does it reset the chip in the key?
It will all end in tears I tell you.......
srad34 is offline   Reply With Quote
Old 12-14-2012, 10:27 AM   #7
pk2
Theres 4 main pairts to the transponder mess,
1) A coded "pill in the key fob
2) and inductive transceiver around the key slot connected to a
3) Mystery box connected to
4) Immobilizer box under seat which sends an A.O.K. signal to
5) the DME
Most likely prob. in my experiences is immobilizer box under the seat gets soaked. Take it out, dry it out, clean it good and you may be O.K.. BUT FIND THE LEAK.
Regards, pk
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
