Old 01-01-2012, 08:40 AM   #1
fullthrottle52's Avatar
Red face Help with new Logo
Hey Gang,
I received a new Boxster logo for the trunk of the Box for Christmas. Just went out and removed the old logo (Part of the B had broken off) with floss. Came right off.
Problem - How do you get the thick rubber backing off that is now sticking to the car? I have tried GOO Begone and it does very little. Of course I have a dark blue car so any messing around will leave permanent scratches around it so you can't use a razor blade or anything like that.
Has anyone done this job before and have any suggestions?
2000 Boxster - Loved and sold
1999 911 Cabriolet - Also loved and sold.
fullthrottle52 is offline   Reply With Quote
Old 01-01-2012, 09:14 AM   #2
Ex Esso kid
Any good cleaner wax or get a tube of Meguire's Scratch X, safe for clear coats removes all kinds of blemishes.
Old 01-01-2012, 09:18 AM   #3
WV Boxster
wvboxst3r's Avatar
cut a razor blade down to width of glue, then use alot of finish detailer(spray on) and be very careful and slow. I have down it on a red saab, no scratches just alot of time and a sore back. Keep the area wet with the spray on wax and try to only touch car where it will be covered. Also was told to heat the area up to relax the glue.
Good luck
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 01-01-2012, 09:21 AM   #4
This is a pretty thick rubber backing that stays on the car when removing the plastic Logo. I don't think any way or scratch x is going to remove it. I would use it after I get the rubbery glue off and clean it up before I put the new one on. It is very obvious that I am going to need to stick the new logo on a clean surface so I need to get it back to the clear coat.
Thanks,
Old 01-01-2012, 09:22 AM   #5
Ex Esso kid
As you wish, I did the same job, use a razor and make one tiny error and it's going to show, try what I told you with some elbow vigor and you end up perfect, your car your choice..
Old 01-01-2012, 09:23 AM   #6
Registered Boxster abuser
healthservices's Avatar
I ended up color sanding one of mine off. I think there was some super glue repairs done in the past with that one. I have not tried to install the other one on the silver car yet.
Old 01-01-2012, 09:46 AM   #7
Multi-Boxer Driver
Deserion's Avatar
When I used to change emblems on my Volkswagens, I would use Goo Gone (citrus based) on a paper towel or terry cloth, and rub the hell out of it. Worked fairly well. Wash afterward and admire the non-scratched paint.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-01-2012, 09:53 AM   #8
Johnny Danger's Avatar
I would consult an auto body shop . They remove these kinds of emblems all the time . When I had my changed out, the shop had a particular type of solvent/cleaner that easily removed the sticky residue without harming the paint . It's foolish to take a razor blade to the finish of your vehicle . Get some guidance from a shop, or pay them a few bucks to do it right .
Old 01-01-2012, 10:11 AM   #9
Johnny, I agree i would have a hard time using a razor blade. I have a body guy I know so I think I will call him tomorrow and ask some questions. It may just take a lot more elbow grease than anything. Much bigger job than I thought. Intended to take half hour but like most projects it usually does not work out that way.
Old 01-01-2012, 10:22 AM   #10
Theoretical propagandist
Eric G's Avatar
In short to remove mine I took Goo Gone and using my finger, sprayed it on the glue...rubbed with finger till I got an edge to "catch" and ran with it.
When it was done, I took and buffed and polished the section down.
Old 01-01-2012, 10:56 AM   #11
Goo Gone, spray it and let it sit for a while, then go to town with your fingernail and papertowel or terry cloth, then scratch-X then wax
fivepointnine is offline   Reply With Quote
Old 01-01-2012, 11:50 AM   #12
here are a couple pictures of the black one after the first color sand and buff. As mentioned before, I think someone put super glue on this one.
click the picture for a better view
I circled the glue spots in this picture...
Hopefully the silver car is not like this too.
Old 01-01-2012, 11:59 AM   #13
Done
Thanks for all the help.
I took the goo begone and soaked it and used the fingernail. 1 hour job but came out great.
Again, this forum comes through with the answers. Just a bigger job than i anticipated. Now if I can just get my tires to run correct I will be all set for a while.
Old 01-01-2012, 03:53 PM   #14
DenverSteve's Avatar
Nice new emblem.
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
DenverSteve is offline   Reply With Quote
Old 01-02-2012, 02:00 PM   #15
I know that the job is already done so this is a little late, but we used a die grinder with a rubber wheel on the end of it at the body shop I worked at over the summer. Mac tool guys usually have them on their trucks. Otherwise, a body supply shop would probably have one.
Vinyl Eraser And Arbor
http://i67.photobucket.com/albums/h3...IMAG0137-1.jpg
00 S Triple Black- Smoked lights, Tinted windows, Stainless exhaust, IwireP ipod cable, desnorkled, painted bumperettes
Jake D is offline   Reply With Quote
Old 01-02-2012, 06:56 PM   #16
I have one of those and definitely do not want to use a high speed die grinder with one of these. Been there done that!
It is basically a eraser. For me it is best used with a slow speed electric drill
Old 01-03-2012, 04:56 AM   #17
And a heat gun or hair dryer should have worked too. Melting the glue off.
ProjectM96 is offline   Reply With Quote
Old 01-03-2012, 10:26 AM   #18
nieuwhzn's Avatar
What about mineral spirits? I use it all the time when removing reluctant glue. Shouldn't attack the clear coat otherwise the frequent gasoline spills when filling up would have eaten away your paint underneath the filler cap by now.
nieuwhzn is offline   Reply With Quote
