Old 12-03-2011, 06:18 PM   #1
schnellman's Avatar
Floor Jack Needed
I hate repeat postings, and I hope this is not one, but I haven't seen the topic before. I am looking for a quality floor jack that is low enough for the Boxster and won't send me to the poor house. I'd like to use it in the garage to remove the wheels one at a time to clean them as well as the brakes this winter. Suggestions as to where to look for a jack and possible prices would be most appreciated. Thanks.
Old 12-03-2011, 06:23 PM   #2
Porscheectomy
Is your car at the stock ride height?
Old 12-03-2011, 08:19 PM   #3
schnellman's Avatar
Yup. Stock everything on a '98.
Old 12-03-2011, 08:26 PM   #4
Porscheectomy
I've been using a Sears low profile jack that was about $75. The lift arm has a hole that can accept a post style adapter to work with Porsches. I had to modify the post to fit under my RoW suspension though. With stock ride height it would probably work fine.
Old 12-03-2011, 08:44 PM   #5
Matt
MileHighBoxster's Avatar
Harbor Freight.
MileHighBoxster is offline   Reply With Quote
Old 12-03-2011, 09:18 PM   #6
Definitely Harbor Freight
I have this
http://www.harborfreight.com/rapid-pump-15-ton-compact-aluminum-racing-jack-68053-html-7814.html
gthompson999 is offline   Reply With Quote
Old 12-03-2011, 09:45 PM   #7
nieuwhzn's Avatar
Originally Posted by gthompson999 View Post
I have the same one, works reasonably well. I wouldn't crawl under the car with only this jack holding it up though. Always use a couple of stable jack stands.
nieuwhzn is offline   Reply With Quote
Old 12-03-2011, 10:28 PM   #8
Idaho Red Rocket 3's Avatar
Any little 2.5 ton floor jack should do the job. Just try not to buy made in China.
2000 Boxster S
Old 12-04-2011, 04:07 AM   #9
Ex Esso kid
Use the stock supplied scissors to raise the side, then you can reach the center jack points without jack saddle modifications. Just remember not to take the scissor out and drop it on the floor jack when you let it down.
Old 12-04-2011, 04:16 AM   #10
Remember theres a central jack point in the back. Its the U shaped brace near the back of the transmission. Just put the jack, with a hockey puck in the saddle, right between the last 2 bolts that hold the aluminum tranny pan onto the u shaped brace and the whole back end comes up.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-04-2011, 04:19 AM   #11
Ex Esso kid
San Rensho, I'm speaking of that same spot but you need to raise the car to get to it with any floor jack I know of, hence the side scissors extra step.
Old 12-04-2011, 06:06 AM   #12
schnellman's Avatar
Once again, you guys (and gals?) are a great source of information.
Old 12-04-2011, 07:27 AM   #13
If car is too low for your floor jack then drive onto a piece of a 2x6 board. That extra 1.5" of height is usually all yoour need.
Vince
m332is is offline   Reply With Quote
Old 12-04-2011, 07:36 AM   #14
Low profile jacks can do it without the scissors jack. My 3 ton Big Red low profile jack fits just fine under my car.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 12-04-2011, 08:14 AM   #15
ddb
www.klisstle.com
ddb's Avatar
When shopping for a jack I pay close attention to the maximum jacking height as well as to getting one with a low enough profile to get under the jacking point. This makes it easier to get the car high enough to get it on jack stands (obviously the height of the stands are important) if this is what you are attempting to do.
For you schnellman this may not be a big issue if you are just removing a wheel at a time for cleaning.
Old 12-04-2011, 09:27 AM   #16
Ex Esso kid
Well I don't see how, I have the stock ride height 98 and my aluminum jack is lower profile than the red 2 ton and there's no way it's happening. Maybe the Dansk muffler was the difference, IDK but the safest way is what I described takes two more seconds to avoid a #$% my car!!!! moment.
Old 12-04-2011, 12:10 PM   #17
Registered Boxster abuser
healthservices's Avatar
more importantly make sure you buy and use jack stands!!!
Old 12-04-2011, 01:21 PM   #18
Porscheectomy
But not all the way up like that!
Old 12-04-2011, 01:52 PM   #19
Ex Esso kid
No lie, the guy under that better be singing nearer my god to thee because he certainly is..
Old 12-04-2011, 07:13 PM   #20
barkinfool's Avatar
On a somewhat related matter, is there any issue created by leaving a car up on jack stands for an extended period of time? Understand that it isn't as stable as on the ground, but just wondering if it might be bad for the car for any reason. Thanks, hope this isn't a stupid question...
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
