Old 12-03-2011, 06:18 PM   #1
schnellman's Avatar
Floor Jack Needed
I hate repeat postings, and I hope this is not one, but I haven't seen the topic before. I am looking for a quality floor jack that is low enough for the Boxster and won't send me to the poor house. I'd like to use it in the garage to remove the wheels one at a time to clean them as well as the brakes this winter. Suggestions as to where to look for a jack and possible prices would be most appreciated. Thanks.
Old 12-03-2011, 06:23 PM   #2
Porscheectomy
Is your car at the stock ride height?
Old 12-03-2011, 08:19 PM   #3
schnellman's Avatar
Yup. Stock everything on a '98.
Old 12-03-2011, 08:26 PM   #4
Porscheectomy
I've been using a Sears low profile jack that was about $75. The lift arm has a hole that can accept a post style adapter to work with Porsches. I had to modify the post to fit under my RoW suspension though. With stock ride height it would probably work fine.
Old 12-03-2011, 08:44 PM   #5
Matt
MileHighBoxster's Avatar
Harbor Freight.
MileHighBoxster is offline   Reply With Quote
Old 12-03-2011, 09:18 PM   #6
Definitely Harbor Freight
I have this
http://www.harborfreight.com/rapid-pump-15-ton-compact-aluminum-racing-jack-68053-html-7814.html
gthompson999 is offline   Reply With Quote
Old 12-03-2011, 09:45 PM   #7
nieuwhzn's Avatar
Originally Posted by gthompson999 View Post
I have the same one, works reasonably well. I wouldn't crawl under the car with only this jack holding it up though. Always use a couple of stable jack stands.
nieuwhzn is offline   Reply With Quote
Old 12-03-2011, 10:28 PM   #8
Idaho Red Rocket 3's Avatar
Any little 2.5 ton floor jack should do the job. Just try not to buy made in China.
2000 Boxster S
Old 12-04-2011, 04:07 AM   #9
Ex Esso kid
Use the stock supplied scissors to raise the side, then you can reach the center jack points without jack saddle modifications. Just remember not to take the scissor out and drop it on the floor jack when you let it down.
Old 12-04-2011, 04:16 AM   #10
Remember theres a central jack point in the back. Its the U shaped brace near the back of the transmission. Just put the jack, with a hockey puck in the saddle, right between the last 2 bolts that hold the aluminum tranny pan onto the u shaped brace and the whole back end comes up.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-05-2011, 05:06 AM   #11
mts
I've had the little 1.5 ton and 3 ton aluminum jacks from Harbor Freight for several years now and they've both worked out well for me (I take the 1.5 for track days).
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
mts is offline   Reply With Quote
Old 12-05-2011, 04:47 PM   #12
barkinfool's Avatar
Many thanks Frodo et al, your post did not come up on my search & answers my question perfectly.
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
