12-03-2011, 06:18 PM
Floor Jack Needed
I hate repeat postings, and I hope this is not one, but I haven't seen the topic before. I am looking for a quality floor jack that is low enough for the Boxster and won't send me to the poor house. I'd like to use it in the garage to remove the wheels one at a time to clean them as well as the brakes this winter. Suggestions as to where to look for a jack and possible prices would be most appreciated. Thanks.
12-03-2011, 06:23 PM
Porscheectomy
Is your car at the stock ride height?
12-03-2011, 08:19 PM
Yup. Stock everything on a '98.
12-03-2011, 08:26 PM
Porscheectomy
I've been using a Sears low profile jack that was about $75. The lift arm has a hole that can accept a post style adapter to work with Porsches. I had to modify the post to fit under my RoW suspension though. With stock ride height it would probably work fine.
12-03-2011, 08:44 PM
Matt
Harbor Freight.
12-03-2011, 09:18 PM
Definitely Harbor Freight
12-03-2011, 09:45 PM
Originally Posted by gthompson999
I have the same one, works reasonably well. I wouldn't crawl under the car with only this jack holding it up though. Always use a couple of stable jack stands.
12-03-2011, 10:28 PM
Any little 2.5 ton floor jack should do the job. Just try not to buy made in China.
2000 Boxster S
12-04-2011, 04:07 AM
Ex Esso kid
Use the stock supplied scissors to raise the side, then you can reach the center jack points without jack saddle modifications. Just remember not to take the scissor out and drop it on the floor jack when you let it down.
12-04-2011, 04:16 AM
Remember theres a central jack point in the back. Its the U shaped brace near the back of the transmission. Just put the jack, with a hockey puck in the saddle, right between the last 2 bolts that hold the aluminum tranny pan onto the u shaped brace and the whole back end comes up.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
12-04-2011, 04:19 AM
Ex Esso kid
San Rensho, I'm speaking of that same spot but you need to raise the car to get to it with any floor jack I know of, hence the side scissors extra step.
12-04-2011, 06:06 AM
Once again, you guys (and gals?) are a great source of information.
12-04-2011, 07:27 AM
If car is too low for your floor jack then drive onto a piece of a 2x6 board. That extra 1.5" of height is usually all yoour need.
Vince
12-04-2011, 07:36 AM
Low profile jacks can do it without the scissors jack. My 3 ton Big Red low profile jack fits just fine under my car.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
12-04-2011, 08:14 AM
www.klisstle.com
When shopping for a jack I pay close attention to the maximum jacking height as well as to getting one with a low enough profile to get under the jacking point. This makes it easier to get the car high enough to get it on jack stands (obviously the height of the stands are important) if this is what you are attempting to do.
For you schnellman this may not be a big issue if you are just removing a wheel at a time for cleaning.
12-04-2011, 09:27 AM
Ex Esso kid
Well I don't see how, I have the stock ride height 98 and my aluminum jack is lower profile than the red 2 ton and there's no way it's happening. Maybe the Dansk muffler was the difference, IDK but the safest way is what I described takes two more seconds to avoid a #$% my car!!!! moment.
12-04-2011, 12:10 PM
Registered Boxster abuser
more importantly make sure you buy and use jack stands!!!
12-04-2011, 01:21 PM
Porscheectomy
But not all the way up like that!
12-04-2011, 01:52 PM
Ex Esso kid
No lie, the guy under that better be singing nearer my god to thee because he certainly is..
12-04-2011, 07:13 PM
On a somewhat related matter, is there any issue created by leaving a car up on jack stands for an extended period of time? Understand that it isn't as stable as on the ground, but just wondering if it might be bad for the car for any reason. Thanks, hope this isn't a stupid question...
Barkinfool
'02 Boxster S
