Old 12-02-2011, 07:28 PM   #1
Gas smell
I have a gas smell coming from the vehicle when it is warm. There are no signs of liquid gasoline dripping from the engine compartment or any other part of the car, and a visual inspection of the engine compartment from both above and from inside the vehicle (with the access panel removed) shows no sign of gas.
Any ideas? This is an 03 986 w/ 83K mi.
Thanks!
Ron
ChairmanRon is offline   Reply With Quote
Old 12-02-2011, 07:56 PM   #2
Porscheectomy
You have to trace the fuel throughout the car. If you can smell fuel, it will be wet somewhere. I have found that it's easy to find the general area of a fuel leak just by following the smell to the strongest spot. Lots of fuel line connections from the tank to the injectors and back. And then there's the fill tube and pump access panel.
Old 12-03-2011, 05:32 AM   #3
Could be that the engine is running rich. Any chance you can check the computer for error codes?
Rich F
somewhere
past: 2000 Boxster S
past: 2010 Boxster S
turbo23dog is offline   Reply With Quote
Old 12-03-2011, 09:07 AM   #4
No engine error codes at all (check with Durametric each week).
Old 12-03-2011, 01:58 PM   #5
Open the front hood and smell around the battery. If you smell gas, remove the battery and battery tray to inspect the gas tank lid and gas lines. Hope you find ...soon !!
milliemax is offline   Reply With Quote
Old 12-03-2011, 07:22 PM   #6
Autobahn Glanz
WhipE350's Avatar
Also drop the panel underneath and sniff around the filter...good luck.
Old 12-08-2011, 05:29 PM   #7
I get no gas smell from the front of the car. It seems to be coming from the passenger side, perhaps the side vent. But there is NO gas dripping from the engine compartment.
Old 12-08-2011, 06:16 PM   #8
Autobahn Glanz
WhipE350's Avatar
Ron - I've been reading the chapters on fuel injection in the Bentley manual. Check out the section on the evaporative control system. Maybe something has come loose or a vacuum valve has issues. There are also several other interesting sections that might be helpful. We all know it takes just a tiny leak to smell gas. Gas wouldn't have to drip to give off smell.
Old 12-08-2011, 07:00 PM   #9
Porscheectomy
Absolutely. It can just be wetting a fuel line or collecting around an injector. If it was bad enough to drip, you probably wouldn't want to be driving it.
Old 03-24-2012, 01:03 PM   #10
Sorry to unearth an old thread but ...
... I'm in the exact same spot. I found an old thread but for 928-s having to do with an Y connector in the passenger wheel well near the evaporative system.
If you have anything - let me know.
I will update once I figure mine out.
Thanks,
01 986 S
fcotanis is offline   Reply With Quote
Old 03-24-2012, 08:15 PM   #11
amschnellsten's Avatar
It sounds to me like an evap problem. Any other symptoms? Howling, hard start after fill up? hard to fuel ect? There is a regeneration valve that can in some instances create a strong odor coming from the passsenger side wheel area exscpecially when warm. Are there any codes present? There are many different areas of the evap system that can have similar symptoms.
amschnellsten is offline   Reply With Quote
