Old 12-02-2011, 01:11 PM   #1
Re-attach rain sensor mirror
I have a 2000 Boxster S. The mirror came un-stuck and upon examination, I discovered a sticky disk on the inside glass that was easy to scrape off and looked like clear double-sided tape. Forum posts dealt with getting the metal disk out of the mirror and using special glue to reattach. This seemed different so I dropped into the local dealer and asked what they knew. At first, dumb looks, then a mechanic said older cars with rain sensors used a special double sided disk that is a Porsche part. They had it, so I was on my way.
My question is, do I need to apply pressure over time, does it need to "cure" or is this a stick and go operation. There is an alcohol swab for cleaning but no instructions, so I thought I'd ask if anyone has experience with this type of fix. Thanks for the help!
DealmakerJoe is offline   Reply With Quote
Old 12-02-2011, 10:42 PM   #2
Matt
MileHighBoxster's Avatar
I have not ever done one that didn't take time to set up. Nothing is instant when it is weight bearing.
MileHighBoxster is offline   Reply With Quote
Old 12-03-2011, 08:37 AM   #3
I thought about this and came to the same conclusion. I've never seen anything, even contact cement, that doesn't perform better when given a chance to "set". I constructed a jig to take the weight off the button and took a picture of it. Unfortunately, when attempting to follow the instructions on the forum for creating an album for pictures, I hit a dead end. There seems to be no place to create an album...at least not anymore. User CP would seem the likely place but no joy. Thanks for the reply
P.S. I did attempt an attachment of pic, maybe that will work. I'm pretty new to this!
Old 12-04-2011, 07:42 AM   #4
Registered Boxster abuser
healthservices's Avatar
I love it!
Old 12-04-2011, 08:00 AM   #5
walt2810's Avatar
Nice setup.
walt2810 is offline   Reply With Quote
Old 12-04-2011, 09:24 AM   #6
Do all "S" models have rain detecting mirrors???
Mrmaddbrad is offline   Reply With Quote
Old 12-04-2011, 09:59 AM   #7
2003S's Avatar
Negative. My '03 doesn't.
2003 Midnight Blue S
LN IMS Retrofit
Old 12-05-2011, 02:01 AM   #8
Location: Seattle - It's not Hell, but you can see it from here!
not here...
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
