Old 10-30-2012, 03:45 AM   #1
tim986's Avatar
Send a message via MSN to tim986
Jim check out ebay and eaton supercharger rebuild kits only cost 100 bucks comes with everything you need
tim986 is offline   Reply With Quote
Old 12-02-2012, 10:45 AM   #2
I got the wide band O2 sensor in today and wired it up to the control electronics. Everything seems to be working. I got a reading of 14.7 with the engine off. I'll know for sure when I see it heat up properly.
Next, I have to wire the SMT6 piggy back into the ECU wiring harness. Here, I ran into a problem. Although I have the Bentley manual which tells me which ECU pin does what what I dont have is the wire colour codes. Does anyone know where I might be able to find which coloured wire does what?
tranceatlantic is offline   Reply With Quote
Old 12-02-2012, 11:36 AM   #3
The Radium King's Avatar
here's one for the 7.2 dme; uncertain how similar it is to the 5.x in your car:
http://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/Electrical_Diagrams/Carrera01A.jpg
Old 12-02-2012, 04:10 PM   #4
Thanks. The diagram in the link looked familiar so I check the back of my manual and the wire colours are there.
Old 12-03-2012, 09:17 AM   #5
pk2
Not condoning this but since you can find the factory "workshop" manual with all the wiring diagrams on the all over the web, mys well. It shows all the pins and wire colors for the DME (and where they go to double check).
I think if you just only squint at the pertinent page then support your local Porsche dealer by purchasing a $3 cigarette lighter for $97, you'll be o.k.
PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
