Old 07-07-2005, 08:54 AM   #1
Door lock beep
When I use my remote to lock my car, the horn now chirps.
I had an aftermarket stereo installed a couple of days ago and I do not recall it doing this before the stereo was installed.
Does the beep or chirp indicate that the alarm is not active, or what?
Old 07-07-2005, 09:09 AM   #2
There is an alarm contact. This contact does not make contact with the body of the radio because the body has a plastic insulator. On the 220 car it is on the left side, so when we put in an aftermarket radio we put a piece of tape on the body to act as an insulator.
On the 210 I think the insulator is on top.
Some people unplug the wire to the contact and then cover the end with tape so it will not touch metal. Then you will not get a beep.
Even with the beep the alarm system still work. The beep is to let you know something is wrong with the system.
Tool Pants is offline   Reply With Quote
Old 07-07-2005, 09:27 AM   #3
deliriousga's Avatar
Check a few things:
Your center console, front and rear trunks. If they are not closed all the way until you hear the latch click it causes the beep. Make sure the console is not stuffed with things to the point were it does not latch.
1966 Wife White/Brown Top
Old 07-07-2005, 02:18 PM   #4
I told ya so!
This was something I mentioned in your other post when you were going to install the head unit....On my 210 there was a tab with a plastic sheath around it which connects to the mounting sleeve.....Mine was on the bottom right as you look into the dash......You have to tape it up and tuck it away so it doesn't make contact with any metal, or your alarm system will give you a false reading......
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
