I told ya so!
This was something I mentioned in your other post when you were going to install the head unit....On my 210 there was a tab with a plastic sheath around it which connects to the mounting sleeve.....Mine was on the bottom right as you look into the dash......You have to tape it up and tuck it away so it doesn't make contact with any metal, or your alarm system will give you a false reading......
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
