Old 11-15-2011, 03:11 PM   #1
Brake pedal to the floor
Hello
Boxster S 2000 with 138 000km. Brake have been done in spring (all disc and pad, nothing else)
Coming back from work today, had to brake hard! No ABS and the pedal goes all the way to the floor. The wheel scream a bit. Scare the hell out of me and stop only 1 foot from other car. Re-accelerate a bit, brake and the pedal goes back to the floor barely braking. I was jam in trafic, good thing for once, so I was able to get back home at about 15mph max.
I got brake a little but as soon I push the pedal too firmly, it goes to the floor.
Brake fluid look like in between min and max.
What could be the problem?
thanks
wawa
wawa is offline   Reply With Quote
Old 11-15-2011, 03:13 PM   #2
Check the brake master cylinder. It is located in the front trunk.
Old 11-15-2011, 03:29 PM   #3
I have look at the booster. Everything look like new. No oil, no rust, it very clean. If anything, its internal and I cant see it.
wawa
Old 11-15-2011, 03:38 PM   #4
DFW02S's Avatar
I bet you're right that it's the booster.
DFW02S is offline   Reply With Quote
Old 11-15-2011, 03:49 PM   #5
Porscheectomy
On most cars, if the brake pedal goes to the floor if you hold your foot down, but will work again if you lift off and press on the pedal again, the seals in the master cylinder are leaking. So if you can pump the pedal and get the car to brake again, you need a rebuild of the master cylinder.
If you can't get the brakes to engage no matter how much you pump the pedal, you have a leak in the system somewhere.
In either case, you probably want someone professional to look at it at this point.
Old 11-15-2011, 04:19 PM   #6
yea I'm afraid its the master cylinder seal that is broken.
Now I dont think I'll be able to drive to the mechanic. I'm afraid I will not have enough brake even with pumping the pedal.
Seams like its gonna be the first run of the boxster on the towing platform
wawa
Old 11-15-2011, 05:50 PM   #7
Gforrest2's Avatar
Depending on how far away your mechanic is, you could take the back roads in the middle of the night and use your handbrake to stop. I've done it before in my Fiat.
Glen
Old 05-25-2013, 05:58 PM   #8
Hey Guys,
Markus here - new member.
Does anyone here have brake pedal travel after a hard brake?
Appareently Boxster and Cayman display such a trait.
Your brak pedal travel experiences?
Markus Vancouver 01 is offline   Reply With Quote
Old 05-25-2013, 07:07 PM   #9
Ckrikos's Avatar
I don't know what you are referring to. I have had my car since new and the brakes are the best part of driving. It when you hit the brakes its as if the hand of god comes down from the sky and stops the vehicle. My pedal goes right back up and even more so the harder you press it down.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 05-26-2013, 02:19 PM   #10
Bad idea - the handbrake in these cars is adequate to stop a parked car from rolling away but that's about it.
'99 black 986
