Old 07-09-2005, 08:05 PM   #1
Anybody looking to do a 3.6L swap?
Here is your chance. I wish I had the fundage right now. 320 hp boxster would be mucho fun
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33615&item=7984575906&rd=1
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 07-10-2005, 06:36 AM   #2
The motor is just the beginning. Then you need a 6 speed tranny, complete exhuast, new intake, ECU, wiring harness, and a bunch of other stuff including custom made pieces. Got $30k?
You're right though... a 3.4 or a 3.6 conversion is something I dream about all the time.
Old 07-16-2005, 08:43 AM   #3
will the 996 3.6l engine direct fit in the boxster no problem
cause one is Rear engine and one is mid engine
ahgil is offline   Reply With Quote
Old 07-16-2005, 12:22 PM   #4
I believe it will fit, but because of the $$$$ factor, most put in 3.4's. Both engines go in "backwards" in a boxster.
Old 07-24-2005, 10:32 PM   #5
986 and 996 engines spin the same direction, the transmissions are different in order to direct the power in different directions.
ljd-924se is offline   Reply With Quote
Old 07-25-2005, 06:18 AM   #6
Brucelee's Avatar
According to my tech, the engine will fit just fine. However, as the first response pointed out .........
Old 07-25-2005, 06:33 AM   #7
Oops! I knew one of them was different... just thought it was the engine. I guess this answers the question, "Can I re-use my existing tranny?" NO!
Old 07-25-2005, 09:26 AM   #8
Wrong
Q: Can I use existing tranny / gearbox
A: No
Is wrong !!!
You have to use the existing tranny / gearbox. Engines of 996/986 spin the same side. The difference is in the gearbox. A boxster gearbox has an extra set of wheels to reverse the direction. So the correct answer is : YES YOU HAVE TO USE a Boxster tranny, a 996 tranny won't work (unless you like 1 forward gear and 6 reverse gears ;-)
Mark.
markk is offline   Reply With Quote
