Old 11-13-2011, 01:44 PM   #1
inside wear on just 1 tire. reason?
The inner side of my right rear tire is more worn out than the opposite side. What would be the first thing I should get check? Alignment? Can it also be a bearing problem? Thanks
ohhh my is offline   Reply With Quote
Old 11-13-2011, 02:17 PM   #2
The alignment spec for these cars calls for quite a bit of negtive camber, which wears out the insides of the rears more quickly than the outsides. If its just one side, I'd start with looking at alignment.
A shop that knows what they are doing can decrease the camber to the minimum of the spec range to avoid the wear issues, but the handling may suffer.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-13-2011, 04:01 PM   #3
Rennzenn
j.fro's Avatar
+1 on alignment.
It's normal to wear the inside edges harder than the rest of the tire, but both rears should be about equal. My guess is that your RR has a bit of toe in.
Old 11-13-2011, 04:33 PM   #4
Going with the NASCAR setup, eh?
Seriously, previous answers are right on the money. Your RR likely has more negative camber (not toe in) than the LR.
Old 11-13-2011, 04:57 PM   #5
Would inside wear(nearly bald) create a "womp womp" sound that is speed dependent and not rpm dependent as well?
Old 11-13-2011, 05:38 PM   #6
Matt
MileHighBoxster's Avatar
Yes. Any tire or wheel anomaly can cause speed-relative handling issues.
MileHighBoxster is offline   Reply With Quote
