Old 11-08-2011, 04:09 PM   #1
John99Boxster's Avatar
Spark Plug Change....Oil?
Changed the plugs today....one of the Spark Plug Socket Connectors had oil in and around it.
Any ideas?
Pic of connector:
http://986forum.com/forums/attachments/boxster-general-discussions/15601d1320797348-spark-plug-change-oil-99660210301-m47.jpg
John99Boxster is offline   Reply With Quote
Old 11-08-2011, 04:28 PM   #2
Oring's on the spark plug tube's need to be replaced. Heat and time kill em. Easy to do.
onaFLYer is offline   Reply With Quote
Old 11-08-2011, 04:30 PM   #3
jsceash's Avatar
What year is your car? 2002 and previous years had a sleeve for each spark plug the orings leak on either end. R&R the sleeve with porsche special tool or a small hooked oring puller and replace the 2 orings. 03 and later nolonger have a sleeve. There is an oil seal between the head and valve cover a little more complicated the valve cover has to be removed, and the seal replaced.
Old 11-08-2011, 04:56 PM   #4
1999 year model. I will replace sleeves and O Rings.....Thanks!
