Old 10-29-2011, 12:27 PM   #1
John99Boxster's Avatar
New Owner.....Advice
Hi all. Just picked up a 99 Boxster, Automatic, Midnight Blue/Savannah Beige.
61,500 miles.
PPI was clean and carfax was clear.
I am looking for advice on how to avoid the Dreaded IMS Failure. Other than keeping the service up to date, What else can I do?
Thanks All
John99Boxster is offline   Reply With Quote
Old 10-29-2011, 12:43 PM   #2
Supposedly, driving it like the Dr. intended it to be driven helps.
brian325is is offline   Reply With Quote
Old 10-29-2011, 02:13 PM   #3
Congrats on the car!
Anectdotal ideas (good ideas but not proven):
  • Use a high quality oil
  • Change oil often
  • Don't be afraid to rev it
Otherwise, either have the IMS replaced or hope that you're not in the small percentage that fail.
Old 10-29-2011, 02:52 PM   #4
  • Change oil often
+1 good oil and change it often, dont baby it! (at least after its warmed up) most people will tell you that Mobil 1 0/40 is NOT good oil, it used to be much much better until they reformulated it a couple years ago.
fivepointnine is offline   Reply With Quote
Old 10-29-2011, 03:05 PM   #5
Good Oil.....I bet that is a highly debatable issue!
That being said....what do you guys recommend?
Old 10-29-2011, 03:16 PM   #6
If you are mechanically inclined, pull the oil sump plate and check for ferrous metal, same thing with the oil filter, cut the ends off and carefully check the entire filter. Any significant amount of metal is not good. Consider getting a magnetic drain plug.
Small bits of dark brown plastic in the sump and filter are usually ok.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 10-29-2011, 04:13 PM   #7
a good oil is usually a group IV or V basestock....redline is good, Motul 8100 is a group IV/V mix, lubro-moly is a very very good quality group III.....go to Bobistheoilguy.com and read your fill about oils!
Old 10-29-2011, 07:32 PM   #8
As stated, change the oil often (no greater than 5k miles) and use at least a 5W40 full synthetic. Once warm, keep the revs above 3000 rpm in daily driving...low rpms and lugging the engine are not good for it.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
