Old 10-24-2011, 05:44 PM   #1
high pitch squeal at startup
hey fellas,
has anyone experienced this? recently, when i start up the car, i notice a high pitched squeal from the right rear. any thoughts of what it could be? do i need to be concerned? it only happens at startup if the engine is cold. and still intermittent. but when it happens, it's very loud and obvious.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 10-24-2011, 06:02 PM   #2
Porsche "Purist"
Paul's Avatar
Air pump? It runs when starting cold
1987 924S. 2002 996TT. PST-2
Old 10-27-2011, 03:35 AM   #3
The would be the starter motor. Search the site for posts on this. My '02 S has had this problem for about 1 year and it seems to get worse in cold weather. Not looking forward to replacement, but I believe that's the best course of action.
gschotland is offline   Reply With Quote
Old 10-27-2011, 07:19 AM   #4
Opposed to Subie Burble
Overdrive's Avatar
Is it like a loud screech or shreek? Or is it a high-pitched whine like a motor spinning, and continues anywhere from a few seconds to a few minutes? If it's that instantaneous screech then go gschotland's route. If it's the continuous whine then you're referring to what Paul mentioned, and that's normal on some startups with the car.
-O/D
IMSR + RMS
Robbins glass window top
Old 10-28-2011, 02:15 PM   #5
Try removing the oil fill cap while the screeching is going on. It would be a test for excessive vacuum (bad AOS). Probably not the issue but the test is so easy it's worth a shot.
Dale_K is offline   Reply With Quote
Old 10-29-2011, 08:13 PM   #6
Mine did it last winter. it's been quiet for months now, but I expect it will start again. jake said it's the starter and it will eventually need replaced, but the noise isn't necessarily indicative of imminent failure.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 10-29-2011, 08:24 PM   #7
My 99 did the same thing, and it did not do it all the time, it was the stater motor.
jbs986 is offline   Reply With Quote
Old 11-04-2011, 01:18 PM   #8
I recently replaced my AOS. No difference in the startup squeal. Btw, my squealing started >10k miles ago.
Old 11-04-2011, 04:26 PM   #9
i just replaced my aos, so i doubt its that. been okay for a while now. but it's weird. very intermittent.
-Tuan
tuanle16@juno.com
