Old 10-23-2011, 11:18 PM   #1
Removing airbag stickers - 3M adhesive remover, alcohol, or acetone?
To remove the annoying airbag warning stickers from the visor, what is the final consensus of the group on the best solvent to use?
1. 3M adhesive remover
2. Denatured alcohol
3. Acetone
or
4. Goof off
Thanks,
Ron
ChairmanRon is offline   Reply With Quote
Old 10-24-2011, 02:48 AM   #2
Rennzenn
j.fro's Avatar
Denatured alcohol...and lots of patience. Goof off will melt the plastic, as will most other strong solvents.
Old 10-24-2011, 04:57 AM   #3
schnellman's Avatar
+1 On Alcohol
... the denatured kind that is. I used denatured alcohol, a small rag, and lots of time to get mine off.
Old 10-24-2011, 07:50 AM   #4
If you want to take a half hour doing each visor, use alcohol. If you want to spend 2 minutes, use laquer thinner.
2003 Porsche Boxster S - Speed Yellow (sold)
2005 Lexus LS430 ML
2006 Lexus GX470
CenterIsl is offline   Reply With Quote
Old 10-24-2011, 01:46 PM   #5
J Tinsby's Avatar
Alcohol
Worked for me and didn't dissolve the vinyl material.
I'd be afraid to use anything stronger that would attack or soften what you are trying to preserve.
Takes all of about 5 minutes or so do to each one, no big deal!
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
Old 10-24-2011, 02:01 PM   #6
I used the sticker cover-ups available pre-cut on ebay. Easy to apply, and they look great
brian325is is offline   Reply With Quote
Old 10-24-2011, 09:21 PM   #7
Autobahn Glanz
WhipE350's Avatar
+1 - I used the strong stuff too, but I also have black seat dye from doing my seats and I used that afterwords...they came out fantastic!!. Would never know there was once stickers, looks like new.
Old 10-24-2011, 11:25 PM   #8
Will laquer thinner do any damage to the (1) plastic mirror cover on the top side; or (2) vinyl on the under side?
Old 10-25-2011, 06:16 AM   #9
+1 on that. They are practically invisible, very easy to apply. Mine have been on for 3 summers now with no fading or peeling.
'99 black 986
Old 10-25-2011, 06:21 AM   #10
Tried alcohol on mine and didn't bulge. Bought the vinyl stickers and they look great.
Old 10-25-2011, 06:57 AM   #11
Porscheectomy
3m adhesive remover didn't work for me. Acetone is probably strong enough to etch the plastic. I used alcohol and it worked, but as mentioned before, it had to soak for 5-10 minutes. That's not exactly painful. It doesn't affect the plastic at all.
Old 10-25-2011, 07:11 AM   #12
Rubber gloves. Denatured alcohol. Finish with 303.
Old 10-25-2011, 11:30 AM   #13
Registered Boxster abuser
healthservices's Avatar
I just did this 30 mins ago. Heavy solvent not a good idea took all of 2 seconds to turn the decal into goo. wiped it off, but it left the the plastic dry, and took some of the grain off.
On the other side I just used WD 40 and fine steel wool. It took all of ten minutes (maybe less if I was not taking pictures) to do.
Old 10-25-2011, 12:50 PM   #14
What is 303?
Old 10-25-2011, 12:54 PM   #15
Originally Posted by ChairmanRon View Post
What is 303?
303 Aerospace Protectant. To bring the nice clean, matte finish back to the vinyl.
Old 03-06-2015, 06:18 PM   #16
SiDGreat's Avatar
I used goof off and it took only 10 min for both
SiDGreat is offline   Reply With Quote
Old 03-06-2015, 06:43 PM   #17
Need For Speed
KRAM36's Avatar
Porsche Sun Visor Cover UPS Decals 911 Boxster Cayman Carrera 997 987 986 996 | eBay
2003 Boxster S
Old 03-06-2015, 07:03 PM   #18
Chuck W.'s Avatar
Easier yet.... I just removed the entire sun visor!
1995 Porsche C4 Cab
Old 03-07-2015, 03:08 AM   #19
WillH's Avatar
Acetone will remove the black paint under the sticker at the same time. Got tired of trying the alcohol... Now I have one bare plastic one
Alcohol rag and patience worked best for me.
Old 03-07-2015, 03:14 AM   #20
I'm a real lucky guy. German delivered cars don't have that ugly sticker.
