Old 03-23-2003, 02:29 AM   #1
Unregistered
Posts: n/a
Unhappy Bad AM radio reception
My dad's Boxster has a bad AM reception problem...
The sound gets worse as he accelerates in gear...
same problem does not occur when at idle or engine off...
anyone have a solution?
Old 03-23-2003, 10:35 AM   #2
Supamatt's Avatar
Send a message via AIM to Supamatt
Put in a CD
I have noticed bad AM reception as well, but have not noticed anything due to acceleration. I don't listen to AM very often so it had not been a major concern of mine. As far as a solution I don't have one mysefl, but suggest you go to your local audio guru's in your town and ask them. I'm sure they would at least be able to point you in the right direction.
Matt Conrad-2000 Porsche Boxster
3rd place Solo II-B Stock CFR SCCA
DigitalInsomnia
http://digitalinsomnia.cc/matt/road.jpg
Supamatt is offline   Reply With Quote
Old 03-23-2003, 05:37 PM   #3
Angry Poor AM reception
Yes, the AM reception is very poor. Here North of Boston there are a number of very strong AM stations and I still have poor reception only 20 miles North of Boston. I agree, use the CD player and forget AM.
William Harris is offline   Reply With Quote
Old 03-24-2003, 08:34 AM   #4
donv's Avatar
With the problem being related to engine running/acceleration, it sounds like a classic ignition noise interference. In the old days, this was very common on lots of cars; the solution was either to find the source of the noise (bad or loose spark plug wire, distributor cap, sometimes even the plug itself) and fix it or get a noise suppressor (electronic filter).
donv is offline   Reply With Quote
