Old 06-28-2005, 05:55 PM   #1
Question HELP!! The boxster is overheating.
Here is the story, just went out for a drive and the Boxster overheated. I put 2/3 of a gallon of distilled water in while setting on the side of the road so I could get home. (here is the strangest part) On the way home I cranked the heat and found that it would blow hot air then cold air without me touching the temperature. I am a tad befudeled by the recent turn of events, originally I thought it would be the thrmostat now maybe the system needs belching or even the overflow tank may need replaced. :ah: Please anyhelp would be great!!
JP-s-in st. louis is offline   Reply With Quote
Old 06-28-2005, 07:24 PM   #2
Brucelee's Avatar
Talking
What do we know?
Low on fluid
Hot and cold temps
Answer:
You have a leak and you may have a thermostat issue.
Time to get it to the shop.
Overheating is simple to diagosis with right equipment.
Also, since overheating can cause permanent engine damage, don't put off resolving right now.
Good luck.
Old 06-28-2005, 07:32 PM   #3
Does anyone have a diagram on the location of the thermostat and the hose routing?
Old 06-29-2005, 07:57 AM   #4
pez
Send a message via AIM to pez Send a message via Yahoo to pez
Auto Atlanta has a decent breakdown..
http://www.********************************************.com/model/986catalog/986.53-a.html
http://www.********************************************.com/model/986catalog/986.53-b.html
http://www.********************************************.com/model/986catalog/986.54-a.html
You can download the whole thing on pdf..
Pez
pez is offline   Reply With Quote
Old 06-29-2005, 02:29 PM   #5
found water
I found water dripping from under the drivers seat???
Old 06-29-2005, 02:32 PM   #6
Brucelee's Avatar
Say more about this!
