Old 08-17-2011, 06:25 PM   #1
squeling brakes
i just replaced my brakes and rotors, with genuine porsche parts. however, they intermittently squel when braking. at the very end right before stopping. is this normal in the "break in" period? was i supposed to put antisquel lubrication on?
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 08-17-2011, 07:55 PM   #2
Autobahn Glanz
WhipE350's Avatar
Yup, go to an automotive store get a bunch of lube and put a bunch on. As you have found the brakes on these cars are really easy to take on and off, should take a quick 30 mins to get them all set and squeal free!
Report back if it doesn't work.
Old 08-18-2011, 07:52 AM   #3
+1 on installing anti-squeal. With the stock pads, that should cure it.
Old 08-19-2011, 07:43 AM   #4
ppbon's Avatar
I'm not a fan of ...
... anti-squeal paste or pads.
Generally, brakes squeal because something is vibrating.
Many times it can be traced to a lose component.
Track pads do inherently squeal because they create more vibration due to their higher temperature and abrasive characteristics.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 08-19-2011, 12:09 PM   #5
jcb986's Avatar
On older cars I always use an anti-squel spray., it helps. Did you properly seat your brakes?
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
