Old 08-12-2011, 09:57 AM   #1
What potential harm may I be causing
by delaying diagnostics to determine the cause of a recurring CEL 0455. Did the obvious and replaced the gas cap. Considering all the areas that may be causing this to occur, what's the worse case scenario?
TIA
dogsivew is offline   Reply With Quote
Old 08-12-2011, 10:09 AM   #2
You head might explode………………..
Seriously, the most common cause of P0455 is a loose, missing or bad gas cap……………
Old 08-12-2011, 10:35 AM   #3
Track rat
Topless's Avatar
If you replaced the cap, cleared the CEL, and the error code returns:
http://www.renntech.org/forums/topic/10045-cel-code-is-p0455/
