Old 08-02-2011, 01:19 PM   #1
need a high res pic of a control arm
Anyone have a lower front control arm hanging around that they could take a good shot of with a camera and email me?
I'm writing up a brief how-to for my local PCA mag about squirting WD40 in the dust boot to stop that squeaky grinding noise that this suspension part seems to develop, but I don't have a control arm to photograph.
The picture will probably need to be at least 3 mb in size, photographed on your driveway so the background isn't busy.
Reply to this if you can do this for me. Thanks!
Old 08-02-2011, 02:06 PM   #2
boxster6354's Avatar
boxster6354 is offline   Reply With Quote
Old 08-02-2011, 02:10 PM   #3
Thanks, but this is a low res web pic. I need a much higher res shot for a printed piece. The file will need to be in the 2+ Mb range.
But I sure would like one just like this but higher resolution! This is exactly what I want, except bigger!
Old 08-02-2011, 02:14 PM   #4
You always want more and bigger............
Old 08-02-2011, 02:20 PM   #5
So true. Just like a woman, huh!
Old 08-03-2011, 10:25 AM   #6
Randall,
What image dpi and file format do you need? Also, can you tell me the print size that the image will be?
I ask because I found the image online that boxster6354 posted and it is a 1476 x 1071 jpg @ 72 dpi.
Even though it has a lower dpi, because of the larger pixel resolution it's possible to increase the dpi to 150 or 300 to get a print size around 6 x 4 and maintain an acceptable image quality.
If you let me tell me the above info and I can change the image accordingly and send it to you. Just pm the info to me and your email and I can send the altered image to you.
- ian
idheaton is offline   Reply With Quote
Old 08-03-2011, 10:31 AM   #7
Thanks Ian. I took the pic above posted by Travis, tweaked it a bit in photoshop and made it work. It's really small, but all I need it for is to identify the part and point out the dust boot for my little article.
It's already on its way to the editor now
