Old 08-01-2011, 04:26 PM   #1
The Radium King's Avatar
coil pack
just finished changing my plugs and noticed that, one one of my coil packs, i was able to pull lhe rubber tube off the pack. there were no problems with it prior to the change, so anyone know if this is an issue?
Old 08-01-2011, 10:08 PM   #2
i was able to separate the rubber tubes from the coil pack as well on a couple of them. not sure if this is normal.
ASpec818 is offline   Reply With Quote
Old 08-01-2011, 10:27 PM   #3
i did a bit more research and they are available seperate pieces. i'm uncertain how they join together, however - press on or twist/screw on (i've read that they twist on, but mine just press together and feel a bit loose).
