Old 07-27-2011, 05:35 AM   #1
Air Bab light on.....again!
Ok, I had my '99 at the dealership 2 months ago to have them re-wire the seat belts as the air bag light stayed on. Everything was great until we went on vacation, after sitting for 2 weeks...air bag light is on....The dealer checked it, no faults and turned it off (no charge**surprise**) Yesterday the air bag light pops on again after only sitting for 2 days. Any clue on what could be going on? voltage issues?
Shotokan is offline   Reply With Quote
Old 07-27-2011, 06:56 AM   #2
ppbon's Avatar
The issues with the airbag are threefold ...
... there's the bad seatbelt buckles, problems with the connectors and problems with the wiring harnesses.
When you connect the PST-II or the PIWIS to the car it will tell you where the issue is since it performs a test of the whole supplemental restraint system (SRS) checking for voltage drops across the entire system.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 07-27-2011, 07:43 AM   #3
Took me 4 trips to the dealer
to finally get mine right. Both seat belts were first. Then a TSB and finally a revised procedure for the TSB according to the tech. Once done right, no problems for 5+ years. The TSB is on my web site. https://sites.google.com/site/mikefocke2/airbagwarninglighttsb
