Old 06-14-2011, 06:15 AM   #1
Jaak's Avatar
Wheels ... any issues?
Folks, I was wondering what sort of issues would I have with the following set up:
From his ad.
Original Porsche Carrera 996 or Boxster BBS style rims.
These wheels were an upgrade from factory, they are called the Sport Classic 2 wheel.
Tires are Conti Sport Contact N1 265/35/ZR18 & 255/40ZR18 .
Rim size and offset are 10 x 18 ET 65 & 7.5 x 18 ET 50.
Part numbers are 993 362 134 55 & 993 362 140 50.
Rims have some curb rash but none are bent, need to sell asap. (Ad is 4 + weeks old, from a body shop).
$1,200 CDN, local pick up.
I called him and he said there is 85% tread left and the rims have a slight bit of corrosion on them, like curb rash. I won't be able to see them for a few days as he is out of town.
How will it fit and what performance issues would there be. I don't hit the track.
Thanks,
Jaak
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 06-14-2011, 06:25 AM   #2
255 front doesn't sound right for 7.5" wide wheel. 225/235 is more appropriate.
Old 06-14-2011, 06:40 AM   #3
Johnny Danger's Avatar
From his ad.
Thanks,
Jaak
It would seem odd that a 18 x 7.5 would be paired up 18 x 10, but it's possible. In any case, neither size is a desirable offset for a 986 application; especially the rears. You would definitely need spacers in order to correct the offset .
Old 06-14-2011, 06:43 AM   #4
Front tires too wide, but rim will fit just fine...rears are completely wrong offset and will require a spacer to get into the ET45-47 range.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 06-14-2011, 07:12 AM   #5
Jaak's Avatar
Folks, thanks ...
My existing 17" wheels are 50 mm front and 52 mm rear offsets for the 2002 S
According to a few publications they suggested a combination of:
7.5 x 18 (ET50) 225/40 ZR 19 & 9 x18 (ET52) 265/35 ZR 18
or
9 x 19 (ET 52) 225/40 ZR 18 & 10 x 18 (ET 65) 265/35 ZR 18
The ones for sale are 7.5 x 18 (ET 50) and the rears 10 x 18 (ET 65) which would place them at either end of the recommendations.
Factory manual suggests 7.5 x 18 (50 mm) and 9 x 18 (52 mm).
The car is a stock 2002 S with 17" twists ...
Old 06-14-2011, 10:41 AM   #6
BYprodriver's Avatar
Front wheel is a OEM Boxster wheel, rear wheel is a 911 wheel you will need a 1" spacer to use on a Boxster & 265/3518 is the best size for the rear. 255/40/18 is too tall to be used on a Boxster, if it is actually 255/35/18 it may fit on the front but the steering will not be as sharp as 225/40 or 235/40.
Old 06-14-2011, 10:51 AM   #7
jaak -
bypro is right. i have this setup on my car. i run the 265/35 in back w/ ET65 offset. i use a 21mm spacer with no issues whatsoever. FYI, any hubcentric porsche spacers will do. i got mine off ebay for like $15. you will also need longer bolts. i forget the length, but i'll measure mine today & let you know.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 06-14-2011, 12:32 PM   #8
Jaak's Avatar
Guys, thanks for the info ... I'll pass on these as it requires too much change ($$$$$).
Friend has Indy P-Car shop so parts are not a problem ... just don't like to spend too much and this will make it not worth while.
I did order a set of correct wheels when I got the car, but UPS lost 3 of the 4 wheels and sent 1 to the wrong address. Took almost a year to get refund. If anyone has a correct set of Classic or Sport wheels in 18" I am interested. I di have a Lady Friend in Buffalo where they can be shipped to. She comes across every two weeks and can bring them with her.
Thanks for the feedback!!!
Old 06-14-2011, 12:34 PM   #9
Jaak's Avatar
That's what I was worried about ... thanks!
