06-11-2011, 03:47 PM
#1
Where does this hook on to?
This hook holds down the fabric on the inside of the top. For the life of me, I can not figure out where it hooks on to.
2002 S
06-11-2011, 07:02 PM
#2
let me know when you have figured it out
I have the same problem ...
06-12-2011, 07:05 AM
#3
Might it be only used
when putting the top in the service position?
06-12-2011, 09:13 AM
#4
no there is one for each side. It hold down the fabric at the corners so that when you open the window the fabric does not fill up like a parachute.
Also according to some, It helps pull the plastic in the center to prevent crimping and avoid the boxster chop when putting down the top.
2002 S
06-12-2011, 01:46 PM
#5
Fixed it.
For those who are wondering where this goes.....Take off the carpet covering on the door jam. About 1/2 way down, next to the seatbelt retractor there is a slot. The same slot that the cover slides into. Feed the hook down and around, hook it in there and it works great.
2002 S
06-13-2011, 06:58 AM
#6
I'll need to check mine, as I don't ever recall seeing it; wonder how it got "unhooked" in the first place?
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
| Thread Tools |
| Display Modes |
Linear Mode
