06-07-2011, 11:20 AM
What are heat exchangers?
All,
I have a 2000 Boxster S. I had the coolant pump go south and bolted on a new one, as well as a new serpentine belt. It still overheats. I have read some stuff on this site that wised me up to the possibility of debris from the disintegrated prop blades in the old water pump still being in the coolant channels, thus causing a clog. Someone suggested I pull the thermistor housing since the bits and pieces may have gathered there. They also suggested doing the same for the "heat exchangers". I have scoured my manual but cannot find any reference to a heat exchanger. Any thoughts on what else they may be called? Also, any advice on how to "burp" the coolant system to get air out, I understand that needs to be done as well. Thanks for any help you may provide.
Jim
06-07-2011, 01:15 PM
Maybe they meant to say "heater core". The air cooled Porsches have heat exchangers to bring warm air into the cabin during the winter. It works great and very fast in my 1997 911 Turbo.
06-07-2011, 01:32 PM
Originally Posted by jlawrence54
All,
Jim
Did the impeller break to peices and plastic bits were pumped through the motor and cooling system? If thats the case, be careful. Jake Raby has some horror stories of cracked heads and blown head gaskets because the impeller bits clog the water pasages in the head and cylinders leading to overheating.
06-07-2011, 01:55 PM
did you open the bleeder valve?
with the car running, are you able to get hot air withthe heater on? If no hot air, then there is air in the heat exchanger. Either way, you need to bleed the system by letting the air out.
The bleeder valve is under the false floor where you fill the oil and water.
check and fill the coolent level when the car is cold. Use porsche coolent or the other approved types. usally the "lifetime" and "add to any color coolent" are ok. after you fill it, open the bleeder, then go drive the car for 20 min. allow it to cool fully and then top off the coolent tank if needed. Leave bleeder valve open for a few days.
Only open the tank when cool, otherwise it will over flow and you have to start over.
Make sure the top is on tight.
2002 S
06-07-2011, 02:21 PM
Maybe they thought you had a 914
06-07-2011, 09:40 PM
The heat exchangers referred to may be the oil cooler on the top of the engine. Or, of course, the rads...
06-08-2011, 06:32 AM
Heat Exchanger (Heater Core) Boxster 986
Part #:997-572-129-00-M262
they are talking about the heater. If it blows cold when the car is warm, you have air in the system.
You need to open the bleeder valve and fill tank and needed.
2002 S
