Old 05-27-2011, 01:58 PM   #1
anyone reuse oem amber corner trim with litronic headlights?
I'm not a huge fan on clear corners, and was wondering how this setup would look like. It seems like everyone swaps the corner trims for clear pieces.
ASpec818 is offline   Reply With Quote
Old 05-27-2011, 02:42 PM   #2
Ummmmmmmmmm……I have never seen amber corners on Litronics. My two personal cars both have clear corners (factory Lits), and I have three cars in the shop, all with Lits and none of them have amber corners.
You need to remember that the amber in the parking lights section of the Lits in inside the light, the parking light lens is clear……..
Plus the only corners available from Porsche, to my knowledge, are either clear corners with headlight washers, or clear corners without headlight washers.
Old 05-27-2011, 03:10 PM   #3
JTP
My car had Litronics with orange corners when I bought it.
JTP is offline   Reply With Quote
Old 05-27-2011, 04:48 PM   #4
JTP Said "My car had Litronics with orange corners when I bought it."
Correct me if im wrong, but your car is a retrofit litronics because factory litronics get defacto headlight washer and your's dont.
Pierre is offline   Reply With Quote
Old 05-27-2011, 06:18 PM   #5
JTP
Yes like the OP asked, this is a case where the previous owner reused the amber triangles after retrofitting the car with litronics. Obviously Porsche didn't let a car leave the factory like this.
Old 05-28-2011, 02:40 AM   #6
Not true, my factory installed LITS came with amber corners.
CasualCarnivore is offline   Reply With Quote
Old 05-28-2011, 07:05 AM   #7
Something is weird here, I have never seen amber corners on factory Litronics, or any other Lits for that matter, plus I’ve never seen factory Lits without headlight washers.…………….
Old 05-28-2011, 07:45 AM   #8
JTP
I bought my 2000 S used in Utah. Litronics were not on the options sticker under the hood so I'm pretty sure it's not factory installed like JFP says. The previous owner probably bought a set of Litronics and just reused the amber triangles.
CasualCarnivore, interesting. Are you the original owner of the car?
Old 05-29-2011, 02:53 AM   #9
No, I'm the second owner of the car. The option code for the LITS is on the sticker so it was factory installed. These Litronics came without headlight washers.
Old 05-29-2011, 06:11 AM   #10
I would be willing to bet the previous owner broke the tab off the clear corners and replaced them with the (less expensive) amber ones. Porsche would not let a car roll off the factory line with such a ridiculous looking clash in the front end design.
I understand not liking clear corners on a civic where the corner light is a whole separate assembly that wraps independently around the side of the car, but on the 986, it is integral to the headlight. It's like painting a white spot on your black hood because you don't like black cars.
nola911 is offline   Reply With Quote
