-   -   trans/diff. fluid change (http://986forum.com/forums/boxster-general-discussions/28907-trans-diff-fluid-change.html)
acbob 05-15-2011 07:10 PM
Can anyone tell me where or what the transverse panel is ? I need to change my 75/90 lube after replaceing axles,seals etc. and can't find the plug, it is under this panel.
Thanks in advance
ACBOB
Steve Tinker 05-15-2011 07:41 PM
The panel is the large alloy triangulated section bolted to the chassis rails. You have to remove the plate to access the gearbox drain plug.
Note that the plate is a very tight fit over its retaining studs and may need a little (gentle) persuasion to remove....
JFP in PA 05-16-2011 09:44 AM
Looks like this:
http://www.skylersrants.com/Blog/Box...a/P0001325.png
