Old 05-14-2011, 09:17 PM   #1
PO447 code ?
I have a 2002 boxster the code is P0447 The canister (open circuit) where should I start I dont even Know where its located Clint > any advice is appreciated
rclint is offline   Reply With Quote
Old 05-15-2011, 08:18 AM   #2
Porsche "Purist"
Paul's Avatar
Possible causes:
Faulty wiring
Faulty shutoff valve
Bad DME
It's controlled by pin 30 on plug 4 on the DME.
1987 924S. 2002 996TT. PST-2
Old 05-15-2011, 09:35 AM   #3
It is located alongside the gas filler tube, behind the wheel well liner on the passenger's side front wheel well.................
Old 05-15-2011, 02:00 PM   #4
Porsche "Purist"
Paul's Avatar
Pull the plug on the valve.
Test the valve's contacts for resistance between the posts. If none, it's "open" and needs to be replaced.
If it tests good, check for continuity between the plug and the DME.
To do this:
Pull the carpet on the front of the rear trunk wall (the one the courtesy light is in).
Remove connector 4 on the DME.
Using a straight pin or another suitable probe and check for continuity from socket 30 to the plug on the valve.
If there is no continuity, trace the wiring for faults.
