Old 04-22-2011, 11:09 PM   #1
Sticky Clutch
Hey All,
Sorry to be pestering the boards lately (Might have something to do with the overhaul i just did)
The clutch, pressure plate etc were all replaced recently, but now the clutch sticks but only in a certain circumstance.
Only sticks when under full acceleration and Revs are above 6,000rpm
it only sticks for a split second, but enough to make the gear change jumpy
thanks for ur help
tobz
2000 Boxster 2.7l, IMS, RMS upgraded
Clarion NX501 GPS Head Unit
Focal 3 way splits, Alpine 4 channel amp
Speed Yellow, 18 inch turbo rims
Canberra, Australia
Tobz is offline   Reply With Quote
Old 04-22-2011, 11:43 PM   #2
Can you try to describe the symptom a little better?
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 04-23-2011, 12:03 AM   #3
Ill try,
Under full acceleration and shifting at very high rpm, i push the clutch in, change gear and then release the clutch pedal, initially the clutch is "stuck" against the floor for a moment and then releases normally.
Doesnt happen under normal driving conditions.
Thanks for any help
Canberra, Australia
Old 04-23-2011, 06:55 AM   #4
You need to bleed your clutch. The brakes and clutch share a common fluid reservoir. Might as well flush brake fluid and bleed both systems.
insite
'99 Boxster
3.4L Conversion
Old 04-23-2011, 01:09 PM   #5
Agree - bleed the clutch and brakes. Use a different color fluid, like ATE Super Blue, so you know when you're done.
Save yourself a world of grief and buy a Motive Black Label European Power Bleeder. You can do a complete flush, by yourself, in about 1/2 an hour. Well worth the investment as this is a job that you should do at least once every two years.
Lots of info in the forum on this, do a search.
'99 black 986
Old 04-23-2011, 03:11 PM   #6
Thanks for the advice! Ill try this next weekend
Canberra, Australia
Old 10-11-2011, 11:42 AM   #7
Similar symptoms when starting vehicle, the clutch had to travel a little further than normal for two weeks to start then it happened! When starting as usual during the depress on the clutch I felt a pop or give way and the clutch was suck all the way down to the floor. In neutral I was able to pull it up with my foot and shift normally however cautious not to go down too far or it would get stuck again. I drove it to the shop and it was diagnosed with two leaks one in the Clutch Master Cylinder and the other in the Master Slave Cylinder. I will have both replaced at @ $900.00. I will pick up this Friday 10/15/2011.
Blackops357 is offline   Reply With Quote
