Old 04-20-2011, 03:36 PM   #1
Parts list for M030 ROW kit
My M030 ROW kit for 986 non-S will be delivered in about a week. Of course it has shocks, springs, sway bars, and sway bar bushings. Is there anything else in the box? e.g. new bump stops, bellows, lock nut, or anything else?
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 04-20-2011, 03:42 PM   #2
manolo's Avatar
Thats all thats in it, no bellows or bumpstops or anything. I ordered my stuff ahead of time from Pelican as I needed new upper strut mounts and bump stops, etc.
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 04-21-2011, 12:26 PM   #3
Are different spring compensation plate thicknesses required? I can't find a definitive answer for which tolerance paint color is found on these springs (white = 3mm; green = 6.5mm compensation)
Old 04-21-2011, 12:30 PM   #4
don't sweat the spring comp plates. just assemble & go.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 04-21-2011, 12:36 PM   #5
+1 on that. The kit is complete with shocks, springs, sway bars and bushings. All good man. No need for anything else.
Just make sure you get the car aligned once you install the kit. If your tires are shot, I would change them too.
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
