Old 04-21-2011, 06:45 AM   #1
HELP needed for Tiptronic shaft
Hi, i replaced my rear right drive shaft assy on my 2003 boxster S Tiptronic 24000km.
This boxster never leak oil on the ground.
When i removed the shaft from the transmission a little amount of oil fall on the ground ??
I check in the cavities where the driveshaft bolt on and i see a little screw in the center of that hole. This screw was loose i tightened it.
Dont know if the oil was coming from there but i dont see any more oil leaks when doing the replacement of the shaft.
Im i ok or do i have to suspect something else.
Help appreciated.
Thank's
Pierre is offline   Reply With Quote
Old 04-21-2011, 07:24 PM   #2
Ecu
ECU ?
Sorry but i dont understand what u talking about.
Old 04-21-2011, 07:47 PM   #3
Spinnaker's Avatar
Originally Posted by Pierre
ECU ?
It is called S.P.A.M.
Old 04-22-2011, 06:58 AM   #4
Need Help
Surely someone here who can answer my question.
Please come on
Old 04-22-2011, 11:22 AM   #5
Lil bastard's Avatar
That's the output shaft retention bolt, referred to as an anti-fatigue bolt. If loose, it will seep a bit of ATF into the cavity between the output flange and the halfshaft (axle shaft).
A drop or so is no problem.
If in doubt, raise car level when warm (not HOT), remove ATF filler plug and you should just get a drip. If no drip, the ATF level is low. If tranny not warm (expanded ATF), you will not get a drip even though the ATF level may be correct.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-22-2011, 04:53 PM   #6
Thank you !
Thank's Lil-Bastard for answer i will better sleep now, i will follow your advice and check the ATF lvl next oil change.
Thank you very much, your help is very appreciate.
