Old 04-21-2011, 06:45 AM   #1
HELP needed for Tiptronic shaft
Hi, i replaced my rear right drive shaft assy on my 2003 boxster S Tiptronic 24000km.
This boxster never leak oil on the ground.
When i removed the shaft from the transmission a little amount of oil fall on the ground ??
I check in the cavities where the driveshaft bolt on and i see a little screw in the center of that hole. This screw was loose i tightened it.
Dont know if the oil was coming from there but i dont see any more oil leaks when doing the replacement of the shaft.
Im i ok or do i have to suspect something else.
Help appreciated.
Thank's
Pierre is offline   Reply With Quote
