Old 04-18-2011, 10:08 AM   #1
Ok to jack up ONLY the rear to change out trans fluid
Hi all,
Been reading guides on doing the trans fluid on this car. Seems like I have to remove the diagonal aluminum support braces, which should only be done with the wheels off the ground (i.e. suspension unloaded) to prevent changes in alignment geometry.
Now, I'm not too worried about getting the right amount of fluid in the trans (i.e. trans level or not) as I have that taken care of seperately, but I wanted to know this:
Is there any reason that I SHOULD NOT remove the aluminum diagonal support braces when the front wheels are loaded/on the ground? I.e. do they somehow still bear a load from the front (I can't see how)?
As a side note, I'm going to be swapping in Mobil One Delvac 75w90, which is $52 for a gallon from Grainger supply. I'll post thoughts afterwards.
99 Boxster 5spd - 64k miles
06 Civic SI - 114k miles, D.D., unbelievably reliable and fun to beat on everyday.
08 Legacy GT 5spd - 74k miles.
JoeFromPA is offline   Reply With Quote
Old 04-18-2011, 10:50 AM   #2
You would be better off if the car was up level; trans will drain better and checking or adjsuting the fluid level is easier.
Old 04-18-2011, 11:39 AM   #3
Understood. However, I am inferring frmo your post that front end load will not affect rear end diagonal brace removal - if this is incorrect, please let me know
Old 04-18-2011, 11:41 AM   #4
manolo's Avatar
+1 on that. I would feel a lot better about being under a car supported by 4 jack stands, rather than two and some chocks that may/may not squirm.
Its better to take an extra couple minutes and do it the correct way. You have a lot to lose and a little to gain, think of it that way!
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 04-18-2011, 12:44 PM   #5
Gentleman (and ladies!) -
I will either be driving the front end of the car up on stacked 2x6's, ramps, etc...
And then jacking up the rear. Haven't finalized htat yet.
However, I will certainly be leaving the front suspension loaded.
My main concern is that by some freak of porsche engineering, leaving the front suspension loaded and removing the rear diagonal support braces could mess with the alignment. I've seen weirder things
I genuinely appreciate the concern - but please bear in mind that I am trying to get a question answered too Still awaiting that answer in the affirmative...
Old 04-18-2011, 01:13 PM   #6
To address your concern, I do not believe that the front end being either loaded or unloaded makes any difference; because ours are on a lift, all the suspension is unloaded, but I really do not see any reason for concern.
A suggestion to make your life simple in the future: Mark the location of your drain plug on the panel you need to remove, and while it is out of the car, use a 2” or so metal hole saw to put an access port in the panel so it will never have to be removed again to drain the gearbox…………..next time you just remove the drain plug............
Old 04-19-2011, 09:28 AM   #7
JFP,
I thought of this many times, and when I was ready to drain my tranny oil I was going to post the question.
It's great having a pro tech on a forum that's willing to take their time to help out us DIY'ers. Thx.
Regards,
paul...
paulv is offline   Reply With Quote
