Old 04-16-2011, 07:18 AM   #1
Aftermarket Exhaust
I have an '01 Box and am thinking about going with an aftermarket exhasut that will provide a little extra hp (maybe) and more impressive sound. Any suggestions?
dennis is offline   Reply With Quote
Old 04-16-2011, 08:07 AM   #2
yoyo7's Avatar
Check out the Fabspeed website...
Excellent workmanship on the product and sounds fantastic. Honestly, not sure about the extra HP on any exhaust system... that can be debated either way.
Have fun in your search.
2004 Boxster S with 29K Miles,- H&R performance springs
- Fabspeed sport exhaust with secondary cat by-pass
- B&M Short shifter, EVO VFlow cold air intake
- 19x8.5 front PS2 235/35/19, 19x10.5 rear PS2 275/30/19
- Kenwood HD6990 Navi, Voce speakers, 8" sub and Hertz amp
yoyo7 is offline   Reply With Quote
Old 04-16-2011, 12:04 PM   #3
Auf los!'s Avatar
Later OEM an option?
Not to hijack the thread, but wouldn't a later ('03-'04) OEM exhaust be an option? I recently came across a 2001 where the owner had done this, and was very happy with the sound.
Anyone know what the difficulties are in installing a later exhaust in an earlier car? There is also the option of the later PSE, which comes with the switch.
Auf los! is offline   Reply With Quote
Old 04-30-2011, 12:55 PM   #4
Thank you, Fabspeed exhaust is also sold through Pelican parts. What about flashing the computer? I called a local Porsche dealer and they said it could add 40 HP and is not detrimental to the car, although it does void the warranty.
Old 04-30-2011, 05:11 PM   #5
40hp with a chip? If so, they’re lying to you. I think the highest gains I’ve seen with a chip/reflash is 15hp on a base Boxster. Turbo cars see greater numbers in chips than NA cars.
Fabspeed Maxflo exhaust is what I recommend and run. Oh and if you email Fabspeed they’ll give you a better price. I got $100 off just by emailing them.
yellowboxster01 is offline   Reply With Quote
Old 04-30-2011, 06:15 PM   #6
Whatever you buy, make sure you get something in writing saying there is no cabin drone or resonance at 2000-3000 rpm or they'll give you your money back. I've yet to hear about an aftermarket muffler that doesn't produce headache-inducing drone with the top up.
Old 04-30-2011, 06:37 PM   #7
Wingnut2u's Avatar
This is just my opinion but no exhaust will increase hp, you may get better sound which makes you think you are going faster but you really aren't. The cost of a Fabspeed or similar exhaust is very expensive since all you are getting is a different sound.
As previously mentioned, almost all of the aftermarket exhausts will give you an annoying drone at 2k-3k rpm. I have done the cheap Chinese exhaust which did have a good sound but had the dreaded drone and it felt like I actually lost low end torque
If you want loud and don't have to worry about having a conversation with your wife while you are driving then go for it. If not, then it will not be money well spent
Just FYI, I have a GIAC flash and a RUF exhaust and they made no noticeable difference in hp. With the GIAC flash I gained a little bit in low end throttle response but my track times stayed the same.
Personally I would spend the $$$ on suspension and DE registration fees
2001 Boxster S
RUF front bumper, Techart side skirts, Gemballa rear bumper, PSS9s, Cargraphic 18" racing wheels, RUF exhaust, GT3 seats
Wingnut2u is offline   Reply With Quote
Old 04-30-2011, 10:15 PM   #8
Johnny Danger's Avatar
Better sound in terms of louder and more aggressive, yes . As far as more hp is concerned, again we're talking about small gains with an aftermarket catback alone.
Old 05-01-2011, 09:20 AM   #9
Well i have that rattle noise that I think is coming form the cats. Can I remove them?
Old 05-01-2011, 09:27 AM   #10
Factory PSE for sound and looks in my opinion. Want power, add headers and bypass pipes. No disappointments!
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
Old 05-01-2011, 11:04 AM   #11
You can delete the secondary cats with out any problems .
Old 05-01-2011, 11:53 AM   #12
I have a 2001. I put in Dansk exhaust and power chip. Very happy with the sound and performance. Sounds better with no drone at low rpms. I would definitely choose this option again.
Richard Griffin
Atlanta GA
2001 blk/tan Boxster 18" turbo twist wheels
2003 gray/tan Navigator
rgriffin is offline   Reply With Quote
Old 05-01-2011, 01:09 PM   #13
DFW02S's Avatar
Fabspeed on an '02 S. (Not mine)
http://www.youtube.com/watch?v=3nha9xnK0QU&
DFW02S is offline   Reply With Quote
Old 05-02-2011, 01:15 PM   #14
I went through two stock mufflers to get rid of the rattle. It was NOT from the cats. My mechanic says the Boxster mufflers are know for this.
In regard to you aftermarket mufflers, I went with a pair of Hushpower DBX mufflers. They are of "moderate" sound level. The sound can be a little annoying with the top up between 2500-3000 rpms but over all I'm very happy with them.
Wret is offline   Reply With Quote
Old 05-16-2011, 09:00 AM   #15
Thanks for all the feedback. I am going to flash my ecu so i will probably remove the cats anyway
