04-01-2011, 05:18 AM
3000 rpm Vibration
I know there has been alot of discussions on the board here about the 3k vibration and what that vibration comes from. My vibration comes at around 3k rpms and is between 69-73mph when I feel it in the steering wheel.
I had wondered if it was the wheels, shocks, tires or the engine mount.
So I decided to give a little test and I may be way off here so correct me if I am wrong. I would get up to 73mph at around 3k and feel the vibration/shake and then put my car in neutral and let the rpms drop and the vibration goes away when the rpms are down and my speed is still in that 69-73 range. This should be telling me that it is the motor mount correct?? Am I missing something here? If it was the wheels I would still feel it with the car in gear or not right??
Please help me with this. Thanks to all.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
04-01-2011, 06:40 AM
I have the exact same issue... Waiting to see replies on this topic.
Jager
04-01-2011, 06:51 AM
In my car, it's independent of speed and get the vibration only when I'm slowing down throgh 3000 rpm. Whichever gear I'm in, if I'm slowing down in gear, I begin to feel the shake at ~3100, and ends as rpm passes 2900. I never get the vibration if I'm accelerating through 3000 rpm.
04-01-2011, 07:34 AM
+1.
I think JTP's not feeling it on the way up because the time spent in that rpm range when accelerating is very small.
04-01-2011, 08:09 AM
I can even be on Cruise Control at 70 and I am getting the VIBE. To me it makes sense that its the motor mount. Thoughts??
Phoenix, Arizona
04-01-2011, 09:04 AM
Again, if it's only at 70, then there's likely something in your wheels, alignment, etc. If you get the vibe in every gear at around 3000, then it's likely your motor mount, or your clutch, or the exhaust, or ???
04-01-2011, 09:12 AM
I had a vibe that occurred in every gear at 2300-2400 rpms. Pretty bad - shook the whole car mildly.
Gone with motor mount replacement and happened at all road speeds for the appropriate gear, so I knew it wasn't rotationally related or balancing/alignment.
99 Boxster 5spd - 64k miles
06 Civic SI - 114k miles, D.D., unbelievably reliable and fun to beat on everyday.
08 Legacy GT 5spd - 74k miles.
04-01-2011, 09:23 AM
There seems to be two causes of this. The front motor mount and the Dual Mass Flywheel. I just changed my DMF and that solved the 3000rpm vibration. Start with the front motor mount then move to the DMF next.
If you end up changing the DMF then do the IMS bearing at the same time...shared labor...assuming it is a 986 and not a 987.
Chris
EDIT: Oops I see in your sig that it is a 97 with over 70k in mileage. Chances are high you need it all; front motor mount, DMF, clutch, IMS....might as well change the AOS while you're there.
87 944S brought back to life
04-01-2011, 09:32 AM
Thanks Dragon
Phoenix, Arizona
04-01-2011, 12:10 PM
Chris
Thanks Dragonwind... I'm gathering a list of hardware I will need to replace the IMS bearing (LN Engineering), clutch assembly, flywheel, RMS, and motor mount. While I'm in there might as well do it all.
Jager
04-01-2011, 04:47 PM
Originally Posted by clickman
+1.
Good point, I'll have to test accelerating at different rates and see if I notice the vibration.
