Old 03-26-2011, 10:34 PM   #1
Chirping sound from the engine problem solved
I know there are lots of threads about this but I'm hoping to make this easy for someone with the same problem.
I started getting this chirping sound from the engine compartment about 2 weeks ago. It sounded like a high pitched "CHIRP" that would come whenever I started the car or occasionally when I jumped on the gas a bit from first gear.
After scouring the net for solutions, the two things that made sense were to tighten the spark plugs and check the idler pulleys. I replaced the belt about 6 months ago so I thought I could rule that out.
I checked the pulleys first because I really hate trying to pull coils from under the car, especially the ones that are closest to the cockpit. Checked all the pulleys and they were fine.
Next I tightened the spark plugs. Out of six, only one felt like it was a shade loose. I washed my normal man sized hands that barely fit into a German engine compartment and then started up the car. NO CHIRP SOUND! :dance:
So if you hear the chirp, try tightening the plugs first.
2001 Boxster - savanna on black
1960 MGA
http://i8.photobucket.com/albums/a18...7/mgaside2.jpg
impboy is offline   Reply With Quote
