Old 02-15-2011, 09:49 AM   #1
Engine and Transaxle Weight
I did some searching but have not found any clear answer on what the fully-dressed engine and transaxle weighs, anyone know for sure?
thanks, jack
nimblemotorsports is offline   Reply With Quote
Old 02-15-2011, 10:00 AM   #2
JAAY's Avatar
the shipping weight on my motor on a palet was 400. If this helps any. The tranny (manual) I can lift my self no problems at about 75-90 lbs i'd say.
JAAY is offline   Reply With Quote
Old 02-15-2011, 10:36 AM   #3
Is this motor fully dressed? or just the long block?
Old 02-15-2011, 10:39 AM   #4
JAAY's Avatar
Yes it is. You wanna make my car electric?
Old 02-15-2011, 11:26 AM   #5
Thanks for the info. And yes certainly I want to make your car electric if you want it converted. What you went to my website? I'm just planning now, I acquired a '97 without engine or trans, the prices of these cars now allows the rift-raft to afford them.
Old 02-15-2011, 09:08 PM   #6
BYprodriver's Avatar
thanks, jack
650 lbs. with a 6speed
Old 02-15-2011, 09:20 PM   #7
Could you elaborate on where your number came from?
Now I have three numbers, 500, 650, and 800.
Old 02-16-2011, 03:07 AM   #8
650!?!?!?!? that seems really heavy.
the 3.4L i just popped in my car weighed in at 424 lb fully dressed EXCLUDING the ac compressor, which i imagine would be another 20lb or so.
the 5-speed transmission weighed in at 91 lb
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 02-16-2011, 10:59 AM   #9
A 3.2 engine weighs almost exactly 450lbs fully dressed with A/C compressor.
kcpaz is offline   Reply With Quote
Old 02-16-2011, 02:28 PM   #10
The Bentley manual says a little more if I did the kilo- lbs. conversion right. Maybe a wet vs. dry variance & I have read 150-175 for 6-speed transaxle.
Old 02-16-2011, 02:31 PM   #11
What does the muffler/exhaust weigh? some are quite heavy, the boxster one looks big.
