Old 02-08-2011, 11:35 AM   #1
Niggles, how to fix.
There's a clunk or clatter from around the right rear strut mount, over bumps, rash.
It's been checked out by pros. Nothing visibly wrong. Suggestions?
Passenger window squeals like a murdered dolphin as it goes up its final six inches.
Lube? Align? Clean? Where?
The CR 220 seems to be temperature sensitive.
Won't run when it's cold. Warm up the interior, and it's on.
Ideas?
Cheers!
eltren is offline   Reply With Quote
Old 02-08-2011, 01:51 PM   #2
lower rear track arm. You will only notice maybe a little oil leakage and dirt at the rubber seal where it bolts to the body.
remove door panel and lube the rails and gears. I used white lithium grease, worked fine for 5 yrs now.
2002 S
jhandy is offline   Reply With Quote
